Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Northern Chapter
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
California, Northern Chapter Join Chapter , Leader: fastmover
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 02:10 AM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is offline
olfordsnstone has a very good reputation on FTE. olfordsnstone has a very good reputation on FTE. olfordsnstone has a very good reputation on FTE.
Bye bye points
Hey guys! How's everyone been lately?
Well, I finally had it with my old distributer. Consistent timing was a challenge and I got tired of screwing with the points gap. Sooooo I went down to Napa and bought new electronic ignition parts (dizzy and coil) then hit the junk yard for a control module and wiring harness. She's running good now and things seem to be maintaining stability so I shouldn't hafta to screw with that ol dizzy no mo.
Tim like... Tim like real good...
A couple of questions though. Do the coils for late seventies through mid eighties 460 engines have a resister built into the coil? Do they even need the stock 74 truck resistor wire in place (which is supposedly wired in on my 74 F250)?
I am using the old (+) coil wire to power the new EI coil. I have been told that the original 74 coil wire has a resistor wire in line. If the new coil has a resistor built it, then I might be double resisting and lowering voltage too low. Does this make sense?
The truck does run very well with the new EI system, but seems to have a slight sputter, or hesitation when accelerating from idle from time to time, but not always. Just wondering if it might be marginal voltage at the coil???
__________________
Tim
05 F350 4x4 CC SB Tow Com 6.0 Auto (camper puller)
74 F250 4x4 w/ C8-460 4sp (restore project and wood truck)
07 Everest 295TS Fifth Wheel (rolling beer drinkin' den)
56 Sweetheart (wife)
These are my ladies
  #2 (permalink)
Old 11-07-2009, 05:10 PM
nevrenufhp nevrenufhp is offline
nevrenufhp is starting off with a positive reputation.
Sometimes if the voltage gets too low, the engine could stall. Then you have to wait a while to start it back up. I did that a few years ago with my Mustang. I used a Duraspark and a GM module though. Now I use a D'spark with an aftermarket Capacitive Discharge ign box. Fires up every time since I put it on 2 years ago.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
  #3 (permalink)
Old 11-07-2009, 06:03 PM
3Mike6 3Mike6 is offline
3Mike6 has a good reputation on FTE. 3Mike6 has a good reputation on FTE.
Another thing (since Dale brought up GM) is all the gG conversions I've done, I hade to change the ignition wire to 14 or 12 ga, from the original 16/18 gauge, since the HEI's needed more current, otherwise at low rpms the engine would want to stal/lsputter.
The wire I'm talking about would be to and from the ballast resistor, or on the newer GM starters from the "S" terminal, IIRC.
Not sure if it pertains to Fords or not.
  #4 (permalink)
Old 11-10-2009, 02:07 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 is gaining momentum as a positive member of FTE.
Not sure if this helps, but here goes:
A few years ago, I put a Pertronix unit on my 6-volt distributer in the 272 Y-Block. When I would pull up to a stop sign it would die. I turned the idle up some and the problem went away. Maybe that would work for you too. Jag
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
