Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 02:02 AM
wikwak wikwak is offline
wikwak is starting off with a positive reputation.
figure this one out ---> DT407 injector pump
I had a '70 Farmall(International) 1456 tractor which had the factory DT407 engine and Roosa Master injection pump. After the tractor would run for approx. 5-10 minutes and warmed up, it would begin to severly loose power, acceleration and RPMs, eventually just shutting down slowly on it's own. My friend and I got a hair-brained idea(we were 13 at the time) to take the fuel enrichment screw off and we bored a hole(about 1/16"-3/32") all the way through the screw, then replacing it on the pump. We ran a small diameter hose off of the head of the screw(which was turned all the way out, as it was before our modification) and up to the fuel tank to return any run-off. This modification not only fixed the "dying" problem, but you could easily tell that a few more horses and Ft/Lbs were reaching the rubber lugs. Can anyone offer some insight on the cause of the problem and the effect of our modifcation? I can only speculate due to my limited knowledge of the pump itself...
Tags
3000 , ford , injection , injector , master , pump , roosa , timing , tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
