Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 11:20 PM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
Ignition switch question
Tonight my ignition switch started giving me a hard time. When I went to pull the key out of the switch with it in Park, I couldn't move the key to the "OFF" position. I did find out if I put the transmission in "Reverse" or nutral it would switch off without any problems. Then the key would pull right out. What is involved with replacing the switch?
  #2 (permalink)
Old 11-06-2009, 11:41 PM
Chicken_Fried's Avatar
Chicken_Fried Chicken_Fried is offline
Chicken_Fried is starting off with a positive reputation.
Try lifting the Park lever up and pulling it out. The switch wears out overtime because of use and people resting their hands on it.
__________________
Tearin' down a dirt road Rebel Flag flyin and a coon dog in the back. Truck bed loaded down with beer and a cold on in my lap -- If you got a problem with that you can Kiss My Country A**
  #3 (permalink)
Old 11-07-2009, 07:50 AM
I tried lifting the transmission lever all around but the only way I found to get the key out was to shift to "R" or "N". I guess it might help to explain what I have. 1987 F250 N/A extended cab automatic transmission.
  #4 (permalink)
Old 11-07-2009, 08:34 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
The problem may be with the ign switch actuator. It is a pot metal thing that connects the key switch to the ign/start switch and also operates the shift lever Park lock. Mostly they fail leaving the shift lever locked in Park but it could be your problem.
Unfortunately you have to tear into the steering column to get at it.
  #5 (permalink)
Old 11-07-2009, 10:58 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Tilt or non tilt wheel also comes into play here.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #6 (permalink)
Old 11-07-2009, 11:42 AM
tilt. Sounds like more fun
  #7 (permalink)
Old 11-08-2009, 07:52 PM
What all is involved with replacing the switch or whatever is messed up? I have the 87 F250 6.9 with a tilt steering wheel.
  #8 (permalink)
Old 11-08-2009, 08:10 PM
shanes66charger shanes66charger is offline
1978 Ford F-150
shanes66charger is starting off with a positive reputation.
The one on my brothers 89 f-150 with 4-speed broke, now our 86 f-250 with 4-speed broke. My brother did the last one and claims its kind of a pita to put a new one in.
good luck..........for now we pulled off the cover and start it with a pliers.
  #9 (permalink)
Old 11-09-2009, 07:38 AM
http://www.ford-trucks.com/forums/87...-actuator.html Some good info here on how to. You can get the actuator at most parts stores for around $10 but a PITA to fit.
  #10 (permalink)
Old 11-09-2009, 08:50 PM
1986 Ford F-250
And if I remember right, the tilt wheel adds 75% of the work.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #11 (permalink)
Old 11-16-2009, 10:50 PM
OK, after I posted the last time the switch started working fine. Is there any kind of lubrication I can spray or let run down thru the ignition switch?
  #12 (permalink)
Old 11-16-2009, 11:54 PM
1986 Ford F-250
To get where it needs to go, I am going to say the steering wheel needs to come off.
Then a good dose of lithium grease on everything that moves, tilt wheel parts as well.
As far as inside the key switch, dry graphite is all I will use.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 11-17-2009, 09:53 AM
fellro86's Avatar
fellro86 fellro86 is offline
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
The ignition lock is not a good place to try, as stated, you need to come in from behind the lock plate and turn signal switch. While you are there, snug up the bolts on the pivot for the tilt wheel... I personally think the ignition switch itself is more likely the issue, as they get to binding after a while. It is possible for the rack gear to be binding as well, and greasing it would work fine. They use a decent grease on them when they assemble them. My 86 is a little hard to operate when cold, but is fine any other time. Could be ignition switch, could be the rack, but I am having some electrical issues starting to show up.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
Tags
diesel , f350 , ford , forum , ignition , switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
