I just posted a few links to how too's on this subject, they might be a few pages back by now but their there. You can pull a spring or 2 and get a small amount of drop in the front and rear the problem being you are going to feel the ride difference and you shocks are no longer going to be working at there best if at all. I believe that the spring removal is covered in one of the links I had but if not it is covered in a article written for this site that should be in the article/spec section or maybe found with a search in this section. Good luck and let us know how it turns out.
__________________
"Nothing is particularly hard if you divide it into small jobs."
"Chop your own wood, and it will warm you twice."
-Henry Ford
