Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 10:53 PM
Chicken_Fried's Avatar
Chicken_Fried Chicken_Fried is offline
Chicken_Fried is starting off with a positive reputation.
Fuel tanks not holding enough fuel?
When I had my truck on the road it seemed like I could only ever squeeze 7-7.5 gallons of fuel into and out of each tank. Would this have anything to do with the fuel pickup? Ive seen pics of those rubber boots messing things up with the pickup. I havent dropped the tanks yet but I will in the near future.
__________________
Tearin' down a dirt road Rebel Flag flyin and a coon dog in the back. Truck bed loaded down with beer and a cold on in my lap -- If you got a problem with that you can Kiss My Country A**
  #2 (permalink)
Old 11-06-2009, 11:06 PM
farmert farmert is offline
farmert is starting off with a positive reputation.
Yes the bottom rubber strainer has probably fallen off. A chunk of fuel line clamped on the steel line will allow you to use the full capacity of your tanks. When installing the ruber fuel line cut it with a V in the loose end to prevent the line sucking to the bottom of the tank.
__________________
1985 F250 Reg. cab 6.9,94 factory turbo, zf5 speed 3.55 4X4 flatbed dual 3.5in. stacks
1990 F350 SRW Crewcab 7.3 turbo 4.10 zf 5spd 4X4
1997 F350 SRW Reg cab powerstroke 4.10 zf5spd 4X4 3inch downpipe 6637 mod
  #3 (permalink)
Old 11-06-2009, 11:09 PM
Okay thanks. How much fuel should be in the tanks then? I think I am going to drop at least one tomorrow to see whats going on. How big is the opening for me to try and dig out the rubber boot?
__________________
  #4 (permalink)
Old 11-06-2009, 11:58 PM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
could be a 16, 18 or 19 gallons i think
  #5 (permalink)
Old 11-07-2009, 12:01 AM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
im purty sure itll b a 19 gallon tank.
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
  #6 (permalink)
Old 11-07-2009, 12:13 AM
Maybe Ill just drop the first tank then at a half a tank now. The rear has a full tank in it.
__________________
  #7 (permalink)
Old 11-07-2009, 01:06 AM
Ok after reading a little more on the problem I had another question.
What can I use as a filter on the bottom of the fuel pickup? I dont trust my tanks enough to not run a filter of some sort.
Also am I able to do any work needed by removing the bed instead of dropping the tanks?
__________________
  #8 (permalink)
Old 11-07-2009, 10:26 AM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
pull the bed its alot easier, plus you can work on other stuff and paint the frame. dont put a filter inside the tanks it will be a pain to change out. when you open up the tanks order a new lock ring set for each tank with a gasket. also search around for fuel fill vent mod and do that so you can fill your tanks faster.
__________________
91 F-250 7.3 N/A ZF-5 2wd, 4" ram air, Isspro gauges, IP turned up, 265/75/16 A/Ts, 15% tint, carter p4594 ele pump, 55w back up lights, class V hitch, 4" exhaust w/14" magnaflow diesel muffler, steering stabilizer (DD/hauler)
88 F-250 460 c6 4x4 Lifted on 36" TSL super swampers, stacks, MSD 6al, holley red, warn hubs (Mud truck)
  #9 (permalink)
Old 11-07-2009, 10:58 AM
Quote:
Alright thanks for the info.
__________________
  #10 (permalink)
Old 11-07-2009, 11:09 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
If you try to drop a tank with 10 gallons of fuel in it, expect about 100 pounds when the bolts come loose.
Getting to the tank from above by removing the bed eliminates that problem.
Most years the tanks were either 17 or 19 gallons for both the front and rear tank.
If you get most of the fuel out, you will be able to look in the tank and see what is in there.
The plastic pieces in the tank from the broken pickup will probably be the worst thing in there and probably the only thing that could cause you grief when a chunk goes into the fuel line.
When you consider the lift pump flow rate, by the time you get to 1/2 tank all of the fuel in the tank has been trough the fuel filter many times.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #11 (permalink)
Old 11-07-2009, 11:20 AM
I was expecting the weight and thats not a problem but I dont want to go through the hassle of dropping the tank. Ill lift the bed one of these days and take a look and fix it all.
__________________
  #12 (permalink)
Old 11-07-2009, 11:39 AM
GenLightening GenLightening is offline
GenLightening is starting off with a positive reputation.
Quote:
The stock "filter" that falls off is really barely a screen. Only keeps out birds and small animals that happen to fall into the tank! I added mesh filters to my pickups, got them at Napa.
__________________
Doug
'88 Chevy 1Ton CC DRW 2WD w/a 7.3l IDI, Banks Sidewinder, E4OD, Baumann controller, Racer-X triple disk TC
  #13 (permalink)
Old 11-07-2009, 06:40 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
The filter at the end of the tube is a saran mesh. It resists passing water, keeping it in the tank. If you are locky it will stop the flow of fuel, saving your IP and injectors. It would be a good idea to put one back on. If you like running bare foot, have at it.
  #14 (permalink)
Old 11-07-2009, 07:08 PM
Quote:
How do I go about getting one of those filters? Would a fuel water separator installed Right after the tanks be a good idea instead? My "water in fuel" light is on so I am going to drain the tanks of water after I run them dry of fuel.
__________________
  #15 (permalink)
Old 11-07-2009, 08:05 PM
1986 Ford F-250
Your truck should have the water seperator built into the fuel filter.
Have you tried draining the water seperator?
My thoughts on water left in the tank, the water seperator is a much better place for the water, that way you can drain it out and get rid of it.
Left in the tank you are more likely to have algae growth in the tank which is worse than water.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Tags
2002 , bed , f250 , flag , flyin , ford , fuel , rebel , tanks , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
