Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 10:25 PM
kell2784 kell2784 is offline
kell2784 is starting off with a positive reputation.
390 to 429CJ?
Am I able to build a 390 into a 429CJ fairly easy, or is it more trouble than it's worth?
Will a FE block fit into the same mounts as my 400 in my 79 F250?
  #2 (permalink)
Old 11-07-2009, 12:52 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
A 390 is a completely different engine than a 429 and in all but a very few rare cases you can't bore and stroke enough to get to 428. A standard bore 390 with a 428 crank is a 410. The 400 has different motor mounts and bellhousing than the FE.
-Johnboy
__________________
-1979 F-250 4X4 351 Cleveland 4spd
-1993 Probe GT 2.5L 5spd
-2009 Focus coupe 5spd Significant others DD
  #3 (permalink)
Old 11-07-2009, 12:59 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
First, heat the 390 to about 3000 degrees F.....
  #4 (permalink)
Old 11-07-2009, 02:43 AM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE.
If you want to do a 429/460 in place of a 390...Go thru the Bronco Graveyard and they carry D&D hedders for the swap, buy the swap kit..there one of our sponsors !
__________________
Blue Saphire 70 F250 42? in the making/Rollerized C6/4:10 Locker
With a Secret BBF/TBA sometime??
  #5 (permalink)
Old 11-07-2009, 02:51 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
The simple answer is NO. You can't get a 429CJ because it is in the 385 family of engines. And the 428CJ has a 4.13 bore and you can't punch a 390's 4.05 bore out that far without hitting a water jacket or having such thin cylinder walls that the engine won't like. That said I did turn an early 390, 375hp into a 406 (4.03" bore) but then those early high performance 390's had a ton of meat in the cylinder walls. There are very few if any late 390's that have that kind of metal around the cylinders.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #6 (permalink)
Old 11-07-2009, 11:40 AM
MeanGene427 MeanGene427 is offline
MeanGene427 is starting off with a positive reputation.
To avoid confusing the poor guy, the 406 was 4.13 bore, same as the later 428, not 4.03. And yes, the later 390 blocks are generally not compatible with that kind of overbore.
I haven't seen anyone put an FE into the lowrider F250 4x4 frame, I put the 427 in my early '77 by switching the mount pedestals with a set from a '72, but my early '77 was still the old highrider frame. 429-460 is a pretty easy swap for your truck, will also match up with the tranny from your 400, and could work to your advantage if your state has a smog program, if you get a '79 or newer pickup 460. My 427 actually passed a sniffer test with a small cam in it, but the visual test Was a lot of fun while it lasted, though
  #7 (permalink)
Old 11-07-2009, 12:57 PM
Bear 45/70's Avatar
Just a typo and a poor proff read. Of course the 406 had the 4.13" bore, just as the later 428 did.
__________________
  #8 (permalink)
Old 11-07-2009, 02:17 PM
johnboy427's Avatar
I am pretty use you can put an FE in a lowboy you just have to use six cylinder engine towers.
-Johnboy
__________________
  #9 (permalink)
Old 11-07-2009, 04:26 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Did it ever occur to anyone he might have meant 428CJ?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #10 (permalink)
Old 11-07-2009, 04:40 PM
Bear 45/70's Avatar
Quote:
Yeah, and that's why so many included info about the 428. But the chances of turning his 390 in to a 428 of any kind are in the slim to none catagory.
__________________
  #11 (permalink)
Old 11-07-2009, 05:16 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Nope it never occurred to me, we know guys come here and post zackly what they mean.
What ever made you come up with a question like that??
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #12 (permalink)
Old 11-07-2009, 05:31 PM
Krewat's Avatar
Quote:
Because he asked about going from a 390 to a 429CJ, and then asked about an FE block fitting into a '79 F250.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
