Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 10:03 PM
MSM0075's Avatar
MSM0075 MSM0075 is offline
MSM0075 is starting off with a positive reputation.
2003 XLS 4.0 Starting Issues
I just bought an '03 Explorer XLS 4.0 4x4w 107k miles on it. This is the second time I'm having starting problems. The previous owner have owned the car for over 4 years and hasn't had this problem. The trucks been fine for me until last week, Some days it will not start. just cranks and cranks. I checked fuel pressure and its in spec. I tried hitting the Fuel Pump Inertia(Spelling?) switch, Tried holding the pedal down to the floor, just a boging sound when trying to start. Nothing. The first time I pulled the the plugs and they were slightly wet and STUNK like gas. Reinstalled plugs, nothing, Next morning, fired RIGHT up. Today same problem. I didn't bother checking anything this time. But I've noticed this is happening when its very moist outside. Engine bay alomst looked wet in some areas.
I don't know what else to check, Can anyone help me to what I should look for? I have plenty of tools to do the job, Just lead me in the right directions please and I'll reply after trying!
Please!
Michael
__________________
Michael
1982 Ford Mustang GT 5.0
1998 Mercury Mountaineer 5.0 AWD
2002 Mercury Mountaineer 4.6 AWD
  #2 (permalink)
Old 11-07-2009, 06:01 AM
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
If the plugs are wet, it sounds like you are getting fuel which would imply it's spark related. Since the problem seems to occur when it's wet outside, that also points to spark. Could be ignition wires, or the crank or cam sensor. Have you pulled the codes? There may be a code stored even if the CEL is out.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #3 (permalink)
Old 11-07-2009, 08:11 AM
MSM0075's Avatar
Quote:
I'll have to check for codes stored. Good idea. Thank you!
__________________
Michael
  #4 (permalink)
Old 11-17-2009, 10:18 PM
MSM0075's Avatar
I wanted to clean the engine bay before I painted the truck. I started it up, let it run. sprayed my cleaner around the engine bay, scrubbed, went to rinse it down, within seconds, engine stalled out. I tried restarting, nothing. I took compressed air to the coil pack removing one wire at a time and taking my air gun to the wires and each section of the coil pack, started right up.....
Still havn't ran stored codes yet..
__________________
Michael
Tags
1998 , 2002 , 40 , awd , crankshaft , ford , fuel , mercury , mountaineer , plug , pressure , sensor , spark , spec , sport , trac , wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
