Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 09:32 PM
msquared100 msquared100 is offline
msquared100 is starting off with a positive reputation.
1966 F600 Solenoid Wiring Harness
Any idea where I can find a 1966 F600 solenoid wiring harness? Thanks.
  #2 (permalink)
Old 11-07-2009, 06:01 AM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
Knowing ford it's the same as any F-series close to that year. Are you looking for an original harness or are you just trying to wire it to work?
  #3 (permalink)
Old 11-07-2009, 07:39 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Welcome to FTE
There is no separate wiring harness for the starter solenoid, it's part of the following:
C5TZ14398BN .. Dash Panel to Engine Wiring Harness Assy / Obsolete
Fits: 1965/67 F500/600 with 330 & 361 engines.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
If your F600 has a 240 or 300 I-6 or 391 4V, no one has these harnesses.
Ford used the SAME starter solenoid from 1956 thru 1979 on darn near every Passenger Car, Truck, Bronco & Econoline.
Find any of these....you could splice in the starter solenoid section of the harness.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #4 (permalink)
Old 11-08-2009, 12:26 AM
Bill, Can you help me out with my VIN? I'm not sure which engine I've got. F60MH517486.
Thanks.
Quote:
Originally Posted by NumberDummy View Post
Welcome to FTE
  #5 (permalink)
Old 11-08-2009, 07:54 AM
Ford Parts Guru
1966 F600? Is it a 1966....or not?
Is this VIN on your registration, or is it from the Warranty Plate, located on the left door face below the latch?
If it's from the Warranty Plate, compare it with the VIN on the registration to see if it matches.
People replaced damaged left doors with used doors. 99% of the time, they did not install the correct Warranty Plate on the replaced door.
F60 = F600 2WD
M = 330 2V Heavy Duty
H = Lorain OH Assembly Plant
517486 = 1964 assembled March 1964
If it is a 1964, the C5TZ14398BN wiring harness is in-correct.
There were three different wiring harnesses used in 1964:
(1) with generator, (2) with Ford (Auto-Lite) alternator, (3) with Leece-Neville alternator.
__________________
  #6 (permalink)
Old 11-08-2009, 10:00 AM
Bill... WOW, you're a wealth of information. Thanks for your help. It's possible that the truck is a 1964. We have 3 1966 1-ton's and I just assumed this f600 was also a 1966. I'll double check the frame plate but I'm certain the door hasn't been replaced. It's not a generator system but is there a quick way to tell whether or not I have an Autolite or Leece-Neville alternator? Would a replacement Dash Panel to Engine Wiring Harness be available for either of these alternators? Thanks again for all of your help.
  #7 (permalink)
Old 11-08-2009, 12:49 PM
Ford Parts Guru
The alternators should be marked as to who manufactured them.
If it is a 1964, most likely it has a Leece-Neville alternator.
C4TZ14398JD .. Dash Panel to Engine Wiring Harness / Obsolete
Fits: 1964 F500/700 223/262 I-6's & 292/330 V8's. Use with Ford (Auto-Lite) Alternator.
C4TZ14398PH .. Dash Panel to Engine Wiring Harness / Obsolete
Fits: 1964 F500/750 all I-6 & V8 engines except diesels / Use with Leece-Neville alternator.
Sorry, no Ford Dealer or obsolete parts vendor has either one.
__________________
  #8 (permalink)
Old 11-08-2009, 06:25 PM
Darn... just my luck. Any recommendations on building one from scratch? Thanks.
  #9 (permalink)
Old 11-09-2009, 08:41 AM
Ford Parts Guru
Compare the harness on your 1964 with one from your 1966.
There's prolly only a slight difference, which means you may be able to use or splice in C5TZ14398BN.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
