Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint and Bodywork
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Paint and Bodywork SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 09:23 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
1989 Ford F-250
My Garage
Ohio Ford Farm is starting off with a positive reputation.
Body Molding
Whats the best / easiest way to get body molding off? I need to remove it from a set of front fenders.
__________________
1986 F150 4X4 351 4vHO It was a 300 I6 RIP Totaled Hit a probe with the snow plow
1988 F150 4X2 302EFI and 35's Still under 100000 orginal miles.
1989 F250 4X4 351W EFI Basket Case.
1991 F250 4X4 351W EFI More rust then metal.
Im just looking for a place to park my ride!
  #2 (permalink)
Old 11-06-2009, 09:29 PM
e-tek's Avatar
e-tek e-tek is offline
e-tek is starting off with a positive reputation.
Quote:
If U mean the stick on kind...spray WD-40 along the sticky part and slowly bend back to allow wd to penetrate. use a plastic edge tool (stripe squeegee, etc) to run under it/pry it off. key is to have the wd release the sticky, not use force alone to pull it off.
if it's a clip on, find if there's a bolt at either end and remove it, then usie a trim tool to snap it off the rest of the clips.
  #3 (permalink)
Old 11-06-2009, 11:23 PM
1989 Ford F-250
My Garage
Sorry Yes its the factory stick on black molding on the bottom body line of a 1989 F 250.
__________________
  #4 (permalink)
Old 11-07-2009, 12:52 PM
Action4478's Avatar
Action4478 Action4478 is online now
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
Are you planning on painting after you remove the molding?...
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #5 (permalink)
Old 11-07-2009, 07:10 PM
1989 Ford F-250
My Garage
Quote:
Yes my Project truck was a custom and I picked up a front clip that was a lot cleaner ( Less NE Ohio Orange ) then my original. However the clip was off a two tone truck and theirs the molding strip on the bottom. I need to remove so I can clean up some small rust areas and start prep for paint. I'll see if I can post a few Pictures a little later on tonight.
__________________
  #6 (permalink)
Old 11-07-2009, 08:05 PM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man is starting off with a positive reputation.
I've had good results using a heat gun. It doesn't ruin the molding and all the stickie residue comes off. If you're gonna re-use the molding you can buy that 3M double-sided tape in rolls and it's better than OEM stuff.
  #7 (permalink)
Old 11-07-2009, 08:34 PM
1989 Ford F-250
My Garage
Quote:
Dumb Question but have to ask.... Do you heat the backside of the body or just heat the molding its self? I have a pretty powerful heat gun.... It will melt lead!
__________________
  #8 (permalink)
Old 11-08-2009, 10:35 AM
Sand_Man's Avatar
Here's my method: use a putty knife and GENTLY wiggle it under the trim piece and put a little pressure on it while you put a little heat on the trim, aiming kinda where the trim meets paint. If you remember nothing else, remember this, if you don't keep the heat gun moving, you will not only ruin the trim, but you can remove paint. Anyway, it really is simple, keep the gun moving, keep pressre on the trim and you'll feel the adhesive "give" and the trim will practically fall off. I took all the trim off a brand new truck I had in under 20 minutes and could've re-used all of it except the first piece that I ruined by keeping the heat on too long. Having said that, start with a small, inconspicous piece and go from there. Hope this helps! Jim
  #9 (permalink)
Old 11-08-2009, 01:07 PM
Action4478's Avatar
taH ssA
I use a old , long serrated kitchen knife , holding both ends away from the paint surface , gently saw back & forth (carefully) tipping the edge of the knife slightly away from the finish . The reason I asked if you are going to re finish it , was I was concerned about the W D 40 silicone contamination , if you use it ,make sure you get it all off before prepping for refinish ...
__________________
Rick.......
  #10 (permalink)
Old 11-08-2009, 02:45 PM
gfw1985's Avatar
gfw1985 gfw1985 is online now
gfw1985 is starting off with a positive reputation.
Try using dental floss to saw thru the adhesive backing
  #11 (permalink)
Old 11-08-2009, 10:28 PM
e-tek's Avatar
WD-40 DOES NOT contain silicone! Most shops use it for that reason. It releases ALL kinds of glues and washes off very easily with your pre-paint (wax&grease remover), not leaving any residual contaminents.
I'd use WD-40 way before heat or a knife. It won't scratch, won't cut and won't warp - either the metal OR the moulding.
  #12 (permalink)
Old 11-09-2009, 01:53 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
3M makes an excellent adhesive remover as well!
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #13 (permalink)
Old 11-09-2009, 10:04 PM
e-tek's Avatar
Quote:
I was gonna mention that in my post above. WD-40 is better than 3M's stuff as well!!
Here's a woodgrain decal - 40 years old. I was going to use 3M's releaser on...used WD-40 instead. Hardly needed the scraper!
Tags
1991 , body , bogy , clips , f150 , f250 , molding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
