Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 08:55 PM
gotjeepzj gotjeepzj is offline
gotjeepzj is starting off with a positive reputation.
Will replacing the bearings at this stage be pointless?
My oil pressure is low and I've got between 2-300K miles so I want to go ahead and replace the mains and rods. I was just going to order the bearings in standard sizes. I'm hoping to get by for a while longer without rebuilding. I know my plan isn't perfect, but I figure it's added insurance.
Does this sound feasable?
  #2 (permalink)
Old 11-06-2009, 09:01 PM
Roanoker494 Roanoker494 is offline
Roanoker494 is starting off with a positive reputation.
There is no way to tell until you get into it. Just a forewarning though, the cam bearings are also a place where oil pressure is lost. You may end up putting money into new rods and mains, and oil pump since you are there, and still have no better oil pressure. With the mileage you are stating I feel that is probably beyond a set of bearings.
  #3 (permalink)
Old 11-07-2009, 01:37 AM
bghnkinf250 bghnkinf250 is offline
1986 Ford F-250
bghnkinf250 is gaining momentum as a positive member of FTE.
Once you get that far into the engine, you are bound to find other things that "should" be replaced, then it will be hard to turn a blind eye. It sounds like you are trying to save for a rebuild or looking for as little down time as possible. If either is the case, why not buy a core, and slowly start rebuilding it on your schedule instead of doing it on the truck's schedule. You can save replacing the bearings and build up the other engine at your pace, while you baby the engine you have in the truck.
__________________
"A man does what he must - in spite of personal consequences, in spite of obstacles and dangers and pressures - and that is the basis of all human morality."
  #4 (permalink)
Old 11-07-2009, 11:47 PM
Quote:
Thats a good idea and excatly what I done on my Jeep Cherokee. I picked up a 4.0L that was past it's prime, for free, and slowly rebuilt it over a couple of months. Swapped it out in less than a day and was gone again.
  #5 (permalink)
Old 11-07-2009, 11:50 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
If the engine has that many miles on it, and still runs ok to do what you want, then I would leave it alone. How much oil pressure does it have? It doesn't have to have much pressure to run ok. If you have 5-10lbs of pressure at idle, and more than that going down the road, it should be ok. If it gets really low, the lifters will start ticking.
__________________
Dave F
1989 F250 XLT Diesel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
