Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 08:51 PM
mismith mismith is offline
mismith is starting off with a positive reputation.
2003 F-350 with 7.3L
I just posted a few days ago about buying a used F-350 DRW and have been really looking for a 2008 with the 6.4. I just came across a sweet 2003 F-350 7.3 today by chance. It is a very clean babied truck, DRW,FX4,Lariat, 1 owner, 73K certified miles! It just got traded in at a local Ford dealership and we are going to look at it in the morning. The salesman says it's immaculate in and out just like the pics I saw. It had a sprayed in liner, never has been cut out for a 5th wheel hitch yet. He checked for me and it has a 4:10 axle ratio. I asked if I could get an OASIS report tomorrow and he said absolutely yes. I can save a ton of money buying this one compared to an '08 or '09. I am only considering it because of the 7.3. What else can you guys tell me about the '3 on question? What should I check tomorrow when we look at it? I think it would serve us just as good as the '08 would since it won't be a daily driver and just used to pull our camper.
Here it is, $20K, good buy or not?
Michael
  #2 (permalink)
Old 11-06-2009, 09:02 PM
dwigmore's Avatar
dwigmore dwigmore is offline
dwigmore is starting off with a positive reputation.
Yep, I'd say it's pretty good. Depends on where you live. If they're asking 20K they likely gave the guy 10 for it on trade. I'd try and shave a couple K off the price just on principle.
__________________
Dean
'02 Lariat Crew Cab Shortbox 4x4 auto.
Stock except for Edge programmer.
Running B100 when the weather permits!
  #3 (permalink)
Old 11-06-2009, 10:31 PM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3 Want-A-Be 7.3 is offline
Want-A-Be 7.3 is starting off with a positive reputation.
Look for leaks under the engine and trans, check and make sure it goes into 4x4, you can do a search here for "What to check " on used trucks, look at the air filter,(clean/dirty) condition of batteries, fluids, any service records, talk to the previous owner if possible for records. OK I found the sticky thread for what to check.
http://www.ford-trucks.com/forums/52...questions.html
  #4 (permalink)
Old 11-06-2009, 10:32 PM
papadelogan's Avatar
papadelogan papadelogan is offline
of Brent's moral decline
papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE.
$20k seems a bit high, but then, that's why (in part) they get referred to as STEALerships.... (parts thru Ed excluded!)
I'd do the following:
1. Crawl underneath the bed to make sure that a GN etc. actually wasn't installed. Some people will weld the metal back in, then spray a bedliner over it to cover it up...
2. Check them balljoints!! From a dealer that's a $1500 job that you can do for $350ish
3. Definitely check the turbo's compressor-side wheel for chips/wear
It sure is pretty, there's no doubt about that!! and only 73k miles??? WOW!! well... it's only a 6yr old truck, so that's about right actually.
Man oh man... I love me a dually. You won't keep up with a 6.4, but you'll have legendary reliability... Track down an '08 tailgate if you want a little more "newness" factor All joking aside, jump all over that. Just 'play' like you're going to walk because they want too much... in this economy (say it with me, 10.2% unemployment) you've got the power BIGTIME.... use it. And post up more pics once that beauty is all yours!!
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;Adrenaline HPOP;UnderCover tonneau cover;05 headlights
  #5 (permalink)
Old 11-06-2009, 10:46 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 is gaining momentum as a positive member of FTE. Bigcat350 is gaining momentum as a positive member of FTE.
Good looking truck Michael. But my opinion a little high but there should be some room to play with. Look in the valley for leaks also and as far as keeping up with a 6.4 you can with a few mods.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #6 (permalink)
Old 11-06-2009, 11:07 PM
camodown's Avatar
camodown camodown is offline
camodown has a good reputation on FTE. camodown has a good reputation on FTE.
Be sure to make sure its a 7.3... the mirrors and door badges look a lot like 6.0 ones... Otherwise, good luck and take your time inspecting!
__________________
2002 F-350 Powerstroke 4x4 Crew Long bed All black Lariat custom Cobra cb mount, mirror signals, t/c lock mod... no chip... yet
  #7 (permalink)
Old 11-06-2009, 11:11 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3 STROKIN'IT7.3 is offline
STROKIN'IT7.3 has a very good reputation on FTE. STROKIN'IT7.3 has a very good reputation on FTE. STROKIN'IT7.3 has a very good reputation on FTE.
Quote:
def. lookin like a 6.blow ......
__________________
WILL PAA #30
2001 F250 XLT Auto EC LB 4x4
THE DP Tuner, a few other goodies
1931 Model A 78-B "Wide Bed"
Join the Virginia Chapter!! http://www.ford-trucks.com/forums/forum147/
  #8 (permalink)
HH60FE's Avatar
HH60FE HH60FE is offline
HH60FE is gaining momentum as a positive member of FTE.
I got the same truck as that, only not a duelly. Paid 18k for it 1.5 years ago from a local dealer. Darn near the same milage too. I absolutely love my truck! The buying power is in your hands. Look it over for things stated above, go with your gut and strike a deal. You will have all the towing power/stability you'll ever want (with a couple in-expensive mods). That rig isn't even broken in yet. You've even got the clearence lights (standard) that I'm missing. The 7.3 is a very desirable engine and has proven its worth. Enjoy.
edit: Oops, yep make sure its a 7.3.
__________________
Matt
2003 F-350 7.3 CC LB, 4x4, a/c, radio and American Flag sticker
"Land of the Free, Thanks to the Brave"
  #9 (permalink)
Old 11-07-2009, 12:51 AM
gp49 gp49 is offline
gp49 is starting off with a positive reputation.
Last June I got a '02 7.3 CC Lariat 4x4 DRW with 77k miles (two owners) for $16.5K with clean oasis. Added new tires about 5k miles later.
Good Luck !
Mark
  #10 (permalink)
Old 11-07-2009, 01:20 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Be Thankful...
2002 Ford F-350
Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all
My thoughts exactly. Looks like a '03 6.0.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #11 (permalink)
Old 11-07-2009, 07:23 AM
knight60626 knight60626 is offline
knight60626 is starting off with a positive reputation.
That is the truck, To hell with the new motors.
7.3 in mine has 300000 on it still gets 12-13 and is driven every day, Its also a tow truck. No smoke or real problems to date. In my opinion the 7.3 is an all around proven motor that you can affordably upgrade and maintain, to me it woud be a no brainer strike deal for the 03.
Pricewise the dealer is always going to high ball you, the money they make on a used car even if it is break even is money they can use. Don't insult them by offering 14,000 but don't be afraid to offer 17,000 and see where they go from there.
  #12 (permalink)
Old 11-07-2009, 07:45 AM
I'd start with the 14,000 number... why not? They're ridiculously high, you go ridiculously low... and meet somewhere in the middle. The lower you start (without being COMPLETELY nuts) is just that: a start. You both know it, so go for it.
and yes, definitely make sure it's a 7.3! I just had a guy in an '03 PSD on my street doing work. $6,000 in repairs this year alone!! And when it came time to pull the tree stump out, he hooked up the 93 7.3 CC Dually to get the job done! I just wish I'd have been there with a camera to get video!
__________________
Brendan
  #13 (permalink)
Old 11-07-2009, 10:13 AM
Be Thankful...
2002 Ford F-350
Just like any car deal, set your ceiling for price and work your way to it without exceeding it.
__________________
Chris
  #14 (permalink)
Old 11-07-2009, 11:02 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
With a chrome & red badge on the door, it's surely a 6.0L (unless someone swapped the badge out). RUN, don't walk from it!! The 6.0L are nightmares until at least '05/'06, and I've seen plenty of failures on those, too. If it really is a 7.3L, snap it up. You'll save a ton over the 6.4L in fuel alone! I'm hearing 9 or 10 mpg on those things.
__________________
  #15 (permalink)
Old 11-07-2009, 11:10 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
Quote:
Actually $14k is about what the truck is worth if it's a 7.3
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
Tags
2002 , 2003 , 350 , 73 , f350 , w
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
