Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 08:44 PM
mathteach mathteach is offline
mathteach is starting off with a positive reputation.
Cranks, but won't start
I have a 2000 F-150 Harley Davidson. I came out of the bank and all of a sudden my truck would turn over but would not actually start. All of the electrical inside works fine, but nothing.
It has been suggested that it is the alternator, also possibly a fuel pump problem, maybe a relay or fuse.
Can anyone give me some insight to what this problem may be.
HELP!!!!!!!!
  #2 (permalink)
Old 11-07-2009, 12:11 AM
S.A.L. S.A.L. is offline
S.A.L. is starting off with a positive reputation.
It's not the alternator.
  #3 (permalink)
Old 11-07-2009, 04:02 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Get some starting fluid spray. Squirt the fluid into the intake and crank the motor.
If it fires the problem is in the fuel system.
If it does not fire the problem is in the ignition system.
Come back and let us know which system the problem is in then we will go from there.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #4 (permalink)
Old 11-09-2009, 12:09 AM
Scottdl99's Avatar
Scottdl99 Scottdl99 is offline
Scottdl99 is starting off with a positive reputation.
Any updates?
  #5 (permalink)
Old 11-09-2009, 12:04 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
IAC maybe?
If you step on the gas while cranking and it starts, revs, and stays running with your foot on the gas, it's the IAC.
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #6 (permalink)
Old 11-09-2009, 12:13 PM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX is gaining momentum as a positive member of FTE. JaySVX is gaining momentum as a positive member of FTE.
If it cranks but doesn't start, it's probably a fuel problem or ignition problem. Check the filters, gas gauge, ignition fuse, ignition relay, fuel pump. Turn the key to on while having your ear next to the fuel pump(may require 2 people or really really long arms) and see if the fuel pump primes. If not, that will cause it. If the fuel filters are clogged and it's not getting fuel, that will cause it. If there's no spark, that will cause it.
__________________
2004 Ford Excursion 6litre PSD
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
Quote:
Originally Posted by Maxium4x4 View Post
I would drive 1,500 miles out of my way rather than to walk through the front doors of any WalMart, OH look! TruckNutz isle 5
Tags
10 , 2003 , 54 , 99 , cranks , f150 , f250 , ford , harley , start , triton , truck , turn , v10 , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
