Cranks, but won't start - Page 2 - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 03-26-2011, 05:08 PM
catman65's Avatar
catman65 catman65 is offline
catman65 is starting off with a positive reputation.
Well it is not promising, had it at the dealer for 4 days and about 2 days in the truck started and has not missed a beat. Dealer put 120 miles on it and could not duplicate once it started. I suspect a bad connection somewhere that they disturbed and it is no longer an issue for now.
Thanks for the info and if it returne i will repost.
Old 01-21-2012, 07:53 PM
Elugaro Elugaro is offline
Elugaro is starting off with a positive reputation.
1997 Ford Explorer 6 cl automatic
My 1997 ford explorer starter went bad so I had it replaced... Started right up but then I turned off the car to make sure it would restart again and nothing! Please help!
Old 02-23-2012, 10:54 AM
vlmach1 vlmach1 is offline
vlmach1 is starting off with a positive reputation.
Check ur wire make sure there tight
Old 02-23-2012, 10:56 AM
Make sure ur battery is charged too.
Old 05-01-2012, 11:24 AM
Wayne Soini Wayne Soini is offline
Wayne Soini is starting off with a positive reputation.
i have a 1999 f250 super duty cranks but wount start . checked all coil packs all have spark. checked all injectors all are spraying but the truck just wount start doent even try to , any one have an answer
Old 05-01-2012, 06:50 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Quote:
Corrosion in the harness.
Old 05-01-2012, 06:51 PM
critterf1's Avatar
Quote:
Need to check for codes.
Old 11-22-2013, 06:18 PM
Rosta Rosta is offline
Rosta is starting off with a positive reputation.
I recently had the crank no start after an initial start and stall. I narrowed down to bad solder joints in the instrument cluster. If the cluster has ever acted up, such as random sweeps or going off then this could be the issue. The cluster has some connection to fuel pump module. I have an 03 supercrew 5.4. Ford dealer in town had never heard of this but I pulled the cluster, found a bunch of bad cold solder joints, fixed them and have not had a start issue since.
Old 11-25-2013, 11:18 AM
Chuck Leach Chuck Leach is offline
Chuck Leach is starting off with a positive reputation.
1980 ford 6 cylinder 300 engine
Have replaced distributor, distributor cap & rotor, spark plugs, carburetor, intake manifold & gasket, ignition module. Have shot starting fluid into carburetor and does not even try to start. turns over good. Carburetor is getting fuel. Just install new exhaust manifold & gaskets to start with, has not started since. Have owned truck since it was new & drove it every day. truck ran very good. "HELP" do not know where to go next.
Old 11-27-2013, 03:02 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Quote:
Welcome to FTE!
I believe you will get a better response to your issue if you post it in the 80-86 section.
Old 12-08-2013, 11:12 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Recheck that U have the distributor timed properly and that U haven't missed a hot wire.
Old 01-31-2014, 01:09 PM
bbking332 bbking332 is offline
bbking332 is starting off with a positive reputation.
I know this seems repetitive, but I found this thread so helpful, thank you guys for this advice! My friend had trouble with his, and it's because I came here did he figure out how to fix it.
Thank you guys
It's coming | Memes.com
  #28
Old 12-14-2014, 07:59 PM
Herman L Scarver Herman L Scarver is offline
Herman L Scarver is starting off with a positive reputation.
Fuel pump problem
I have a Ford E 250. I parked it on an incline and loaded some things in the back. When I was ready to go it wouldn't start. I could hear the fuel pump running. I sprayed some starting fluid into the intake and it started but cut off after burning off all of the starting fluid. I took the fuel line off of the fuel filter and turned the key but no fuel came out even though I could hear the fuel pump running. Can someone give me a suggestion on where to go from here?
  #29
Old 12-15-2014, 12:15 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
gotta be a bad pump...have you pulled any codes? how much gas do you have in tank?
Quote:
  #30
Old 03-22-2016, 07:23 AM
j chris cloud j chris cloud is offline
j chris cloud is starting off with a positive reputation.
Quote:
Originally Posted by mathteach View Post
I have a 2000 F-150 Harley Davidson. I came out of the bank and all of a sudden my truck would turn over but would not actually start. All of the electrical inside works fine, but nothing.
It has been suggested that it is the alternator, also possibly a fuel pump problem, maybe a relay or fuse.
Can anyone give me some insight to what this problem may be.
HELP!!!!!!!!
Just had this issue with my 2002 F250 4WD 5.4 V8. All my fuses and relays were good. Went to pull cam sensor, and water temp sensor... checked coils for voltage, found none with the key on. should show 12V at coil. Final analysis, in MY case, it turned out to be a three volt voltage drop at the positive battery terminal. I aborted the stock terminal, which was comprised of this terminal block with three red cables coming from it. one from alternator, one to starter, one to ....wherever. I replaced that with a honkin' aftermarket battery terminal, cleaning both pos and neg terminals on the battery. Truck fired right up. I'll post pics if I can figure out how....
2002 No Start Problem D.Yaros 1999 to 2016 Super Duty 9 01-15-2017 02:49 PM
2000 f250 7.3 wont start. Kg2466 1999 to 2016 Super Duty 3 11-25-2015 07:40 AM
A very weird no start problem natew 6.0L Power Stroke Diesel 16 11-16-2015 12:22 PM
TCU gyesko 1999 to 2016 Super Duty 13 08-16-2013 06:20 PM
Wont start unless I hold shifter up. Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-25-2011 07:47 PM
Tags
10, 2003, 54, 99, cranks, f150, f250, ford, harley, start, triton, truck, turn, v10, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
