Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 07:44 PM
down n dirty down n dirty is offline
down n dirty is starting off with a positive reputation.
Angry 06' F-350 PSD GPM
Hey guys I have a 06' F-350 4x4 dually psd automati with 4:10 gears. Truck has ran great with so so fuel mileage up to 4 weeks ago when it let me down due to a bad (injector computer) that was replaced under warranty. Now the truck running empty @ 70-73 mph is getting about 14-15 mpg. And when I tow my 16,000 lb trailer I'm getting 8.2-8.5 mpg on flat ground. Is this common? If so what can I do to increase my mileage? Chip; larger exhaust; k&n cool air filter unit etc. Any info will be certainly appreciated. Thank you
  #2 (permalink)
Old 11-06-2009, 08:13 PM
imprezdcrew imprezdcrew is offline
imprezdcrew is starting off with a positive reputation.
i feel your pain... i have an 06 4x4 psd auto cc lb dually with 4.30 gears. when i first got it i would struggle to get 13 mpg with it... now i get 13 perty easily... thanks to it breathing and fueling alot easier.)
i would recomend letting it breath and making sure you compensate fuel wise for it.
my guess is with 4.10's you should get beeter milage than mine.
good luck... and if you want an affordable exhaust send me a pm =-)
  #3 (permalink)
Old 11-06-2009, 11:00 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
The mileage seems fairly normal for a 6.0L. If you were doing better before, did they reflash the PCM or FICM? At any rate, I would stay away from a K&N filter set up. The stock Donaldson air filter will be all you need until you start making some serious horsepower, as in over 500. You might give getting the FICM reprogrammed to improve mileage some thought.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
