Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 07:39 PM
USAF FordGuy's Avatar
USAF FordGuy USAF FordGuy is offline
USAF FordGuy is starting off with a positive reputation.
Welding Front Spider Gears
Would doing that affect city driving even in 2wd mode?
  #2 (permalink)
Old 11-06-2009, 09:38 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
no, it will be fine in 2wd.
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
  #3 (permalink)
Old 11-06-2009, 11:44 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
And it'll only want to go straight ahead in 4wd.... that is until you break the welds and destroy the diff. This is always a bad idea unless it's for a 1 use derby type event.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #4 (permalink)
Old 11-07-2009, 04:09 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
Ditto to Conanski's post. Other than cost, what's wrong with a locker? They are less expensive in the long run considering how quickly you will end up replacing the differential components anyway.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #5 (permalink)
Old 11-08-2009, 08:16 PM
hdfe hdfe is offline
hdfe is starting off with a positive reputation.
NO NO NO, very bad ju-ju... Won't turn. I did that to an old Nissan 4x4 mini years ago and blew the diff into little chunks. Did I mention it won't turn? (!)
  #6 (permalink)
Old 11-08-2009, 10:23 PM
In 2wd it will be fine. In 4wd it will act like a spool. No good on the street. But neither is my locker unless the street is covered with snow.
__________________
  #7 (permalink)
Old 11-08-2009, 11:11 PM
Encho's Avatar
Encho Encho is offline
Encho is starting off with a positive reputation.
The diff. is there for a reason, try turning all the tires at the same speed always and you'll not only break the diff. you'll also wear your tires way faster. The locker works temporarily (when needed) and only in soft terrain.
__________________
1993 Special Edition Bronco (EB equivalent)
5.0lt V8, E4OD Auto
Member of the International Chapter
  #8 (permalink)
Old 11-09-2009, 08:53 AM
People run spools without breaking the diff. This would be no differnt. My locker (lock right) is so tight, it is basicly locked all the time. It does suck on dry pavement. But it will turn and I havent broken anything in the diff. I dont lock the wheels on dry pavement. So it has no effect on tire ware. Understand, I'm not recomending this, but it can be done. Depending what hes using it for, it may be fine.
__________________
  #9 (permalink)
Old 11-09-2009, 04:04 PM
1992 Ford Bronco
I still wouldn't recommend it for the front. You have three u-joints in the TTB axle that you are abusing along with the differential and tire wear issues. Even a very tight locker will give up its hold when the rpm differential between inside and outside tires is high enough to warrant it. I realize that money can be a concern but if you weigh the cost of a locker against the cost of the repairs you will end up having to do, there just isn't a good reason to do this to a front axle. My $0.02
__________________
  #10 (permalink)
Old 11-09-2009, 04:08 PM
That's what I thought, friend thought it would be a good idea, just needed more proof for my side of the argument
Tags
15 , 1550 , 1990 , 1990f250 , 2wd , 38 , differential , differintial , ford , front , gears , lockers , spider , tires , truck , welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
