Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 07:33 PM
Saxon Saxon is offline
Saxon is starting off with a positive reputation.
Can't get enough Bass -'89 F-150
I had 2 bazooka tubes, 6.5", behind the seats that wore out. then I put a 10" JBL 2 ohm in a wedge box. it works but ain't got any punch.
Amp power is 90 x 2 @ 2 ohms or 180 x 2 @ 4 ohms
What can I get in this regular cab?
I wonder if bazooka tubes 'side firing' is better than wedge box 'front firing'?
__________________
2004 F-250 6.0 CC 4x4
1989 F-150 300-6 4x4
  #2 (permalink)
Old 11-07-2009, 10:45 AM
AudioNutz's Avatar
AudioNutz AudioNutz is offline
AudioNutz is starting off with a positive reputation.
What have you listened to so far?
__________________
-Bill
2003 IASCA Amateur Street World Champion
2003 SLAP Amateur Street National Champion
Linear Power - Dynaudio - Sony - Scosche
My Little Truck My Other Projects
  #3 (permalink)
Old 11-07-2009, 06:26 PM
2 bazookas 6.5" 4 ohm
1 JBL 10" 2 ohm
The JBL is a GT1041d 18W - 275W and my amp is supplying 90W
__________________
  #4 (permalink)
Old 11-08-2009, 07:13 PM
oh and so far I have listened to:
Neil Young
Motley Crue
Lynard Skynard
Iron Maiden
Alan Jackson
get the point.
__________________
  #5 (permalink)
Old 11-10-2009, 03:09 AM
angus angus is offline
angus is starting off with a positive reputation.
Figure out the biggest possible box you can fit back there. Make a prototype out of cardboard or foam or something. Calculate the internal volume using geometry or by filling it with buckets of dirt. Once you know the volume (in liters or cubic feet), someone here should have advice on what woofers can fit there.
__________________
1957 panel delivery / 1959 M100 flareside / 1960 M100 styleside / 1960 panel delivery
  #6 (permalink)
Old 11-10-2009, 06:42 PM
ReadOrDie_WoW's Avatar
ReadOrDie_WoW ReadOrDie_WoW is offline
Import Killer
ReadOrDie_WoW is starting off with a positive reputation.
All I drive is regular cabs, first try turning your speaker around to bounce the air off the back of the cab, the principle behind this is that it takes a full 12 ft for bass to really shine, so any way you can lengthin the distance between source and destination will make the bass more prominent, for the longest time I ran one 12" kicker wedge behind the front seats with 500 watts hitting against the back of the cab and reverberating against the rest of the inside, its enough to make your teeth rattle and your eye sight blur... so 100 watts should make decent sound, but I would suggest finding a cheap 200/300 watt amp to keep from screwing up your speaker, they aren't designed to run on low amps, and I have blown a few speakers (new mind you) from underpowering them. I don't have any suggesting with bazookas because I don't use/like them.
__________________
94' Ford F-250 7.3 IDI Custom "Baby Blue"-08' Dodge Ram 1500 4.7 Custom "the Grey Ghost"
"Because life's to short to drive a chevy."~RoD
  #7 (permalink)
Old 11-11-2009, 10:48 PM
bgalaxy67's Avatar
bgalaxy67 bgalaxy67 is offline
bgalaxy67 is starting off with a positive reputation.
I would start with working with the room you have to work with for a box and then we can go from there. The right sub in the prefect enclosure will by far out perform any prefab system.
As far as amps go, you will want something that matches the sub. You will want a quality amp with a little headroom. don't buy cheap, it's just more hassle then it's worth. If you buy right the 1st time, it will be cheaper then replacing junk over and over.
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
  #8 (permalink)
Unread Yesterday, 08:13 AM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
You can fit up to 3 10"s depending on your design. My buddy has a older chevy reg cab. about the same size as your f150 and he has 2 10"s they also make shallow mount subs.
__________________
95 F150 XLT Extended Cab. Short Bed 5.8L 351 Windsor 4x4 200k + and running strong! Built FORD Tough!
Next step- Bigger tires, some lift and some more ponys!
Tags
1989 , 65 , bass , bazooka , box , chevy , f150 , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
