Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 06:45 PM
Buckin_Bronco's Avatar
Buckin_Bronco Buckin_Bronco is offline
1989 Ford Bronco
Buckin_Bronco is starting off with a positive reputation.
351w hp gains
Hey guys i have a 351w efi with stock heads and was wondering what would be the best way gain some extra horses. thanks
  #2 (permalink)
Old 11-06-2009, 07:08 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
The best additions in my opinion are a roller cam, aluminum heads, adjustable valve train, stroker kit, then power adders and better internal components.....
I ordered that in order of what you will pay and what you will get for the money for a street strip performance engine.
  #3 (permalink)
Old 11-06-2009, 10:12 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE. Blurry94 has a very good reputation on FTE. Blurry94 has a very good reputation on FTE.
How much are you looking to spend and what kind of power are you looking to make?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, ARP hardware, Canton main girdle, FMS Mass Air and tuned with SCT software.
  #4 (permalink)
Old 11-07-2009, 01:08 AM
1989 Ford Bronco
I am looking for around 400 hp in the range of $3000. and i was also wondering if you could bolt an E4OD up to a 351w
  #5 (permalink)
Old 11-07-2009, 11:03 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
If the trans is from a small block then yes it will bolt right up.
You didn't say what year this truck is but unless it has mass air 400hp is beyond the capabilities of the stock EFI system. With mass air it's entirely doable but it will require fuel susyem upgrades on top of the engine modifications. To get to that number or relatively close you're looking at a complete HCI swap and new exhaust including headers.
On the other end of the scale simply swapping in a better cam and adding headers will put the motor in the 300hp range with big TQ and it can be done with even the old SD EFI system.. just takes careful cam selection. No fuel system upgrades needed at this level assuming the pump is operating up to spec.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #6 (permalink)
Old 11-07-2009, 05:29 PM
Blurry94's Avatar
If the motor is in good working order, good leak down and compression, you can bolt on a Vortech for roughly 3 grand; or pick up a used kit for roughly half that. A complete kit will come with the fuel and ignition components needed to support the boost pressure along with the bracketry, ductwork and compressor and it can be installed in about a day.
__________________
Matt C.
  #7 (permalink)
Old 11-08-2009, 12:41 AM
1989 Ford Bronco
the truck has a rebuilt 351w with flat top pistons not sure what compression is but engine only has 4500kms on it. the year of the engine is 1991. Im wondering if i could go with a vortech if i have flat top pistons because compression is higher than stock. thanks guys
  #8 (permalink)
Old 11-08-2009, 12:31 PM
Blurry94's Avatar
No more than 10:1, somewhere between 8.5-9.0 to 1 is ideal. One drawback nowadays is that you need to run premium fuel for supercharged applications.
__________________
Matt C.
  #9 (permalink)
Old 11-09-2009, 10:59 AM
1989 Ford Bronco
would a set of aluminum heads be a good alternative boost of power. I had heard that you could get up to 100hp gain just from heads.
  #10 (permalink)
Old 11-09-2009, 11:55 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
what vehicle is this motor in?
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #11 (permalink)
Old 11-09-2009, 01:25 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
Nitrous is a very inexpensive way to get 75-100 hp easily and as lomg as you stay conservative in the use it will have very minimal negative impact of the engine.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #12 (permalink)
Old 11-09-2009, 06:21 PM
1989 Ford Bronco
the engine is in a 1989 ford bronco full size XLT/4'' lift 35'' tires
  #13 (permalink)
Old 11-09-2009, 06:49 PM
Blurry94's Avatar
I can see 100hp with a set of heads and a cam, but not with heads alone. Heads, cam and a good exhaust system will get you that 100hp with the proper fueling.
With that size tire, I would think you'd also benefit from a gear swap.
__________________
Matt C.
  #14 (permalink)
Old 11-10-2009, 12:09 AM
with 35's you need to run 4.56 minimum. im running 4.88's to give me a little extra and i can say had i gone with 4.56 i would have been really unhappy. Do this before you go modding the motor any because the gears will provide the biggest gains period. then see if you truely need all that extra juice.
im very happy with my setup and the motor is running jba shorties custome y and 3" exhaust otherwise its stock. I have an edelbrock efi truck intake waiting but havent felt the need yet to install it. Gears make all the difference
__________________
  #15 (permalink)
Old 11-11-2009, 12:39 AM
1989 Ford Bronco
does anybody know what would be a good cam for a fuel injected 351w without causing major issues with the ECM. Also if i were to go with heads what do you think would be a good choice. Thanks guys
Tags
1989 , 351w , cheap , ford , gains , gears , horsepower , hp , ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
