V-code spring upgrade questions
#91
search for posts by Alaskanex. This young man has just put X codes on and has a lot of pics.
https://www.ford-trucks.com/forums/9...t-springs.html
#92
#93
I did v front and mod b rear springs to my Ex
I used a set of v code front springs with the second leaf shortened from my stock EX front springs and the b code rear that were modded with the 2 shortest leafs from the stock EX springs.
This raised my front from 37 1/2 to 40 1/2 in the front from ground to wheel well and in the rear with the stock 2" tapered blocks and the modded B code springs it went up from 39" to 42". I wont be using my 3" blocks as they arent needed.
I love the new stance of a slight rake from front to back and 3" higher overall.
#94
difference in springs what is recommended
Couple of questions for you guys.
I dont know the difference betweeen the v, b, and x code springs.
How do I know what spring is which (where do I find the code)?
What combination would be recommended to give me around 3" lift and be the best for heavy tongue weight.
Should I stay away from buying used leafs or should they be OK
Thanks I know you guys will set me in the right direction
#95
V and X are front springs. The difference is weight rating. I put used Vs on my Ex and it raised the front 2". I see no issue using used springs cuz if you bought a used truck you got used springs and unless you had a specific problem with the springs you wouldn't change em. The X code were used on F350s withe a snow plow package or F550s.
B codes are rear springs that also have abetter weight rating and better spring movement rate. This gives a lift as well as better ride(if I have read previous posts correctly).
I have a F250 I'm gonna get W codes(F450) for the front and have 3." blocks for the rear. Yep Used...
#96
#97
#98
#99
#101
#102
Right side 3.5" tapered block Part #F81Z-5598-GA
FRONT SPRING V CODE SPRING 2C3Z-5310-HA use 2 $129.58
AXLE TO SPRING U BOLT F81Z-5705-ZA use 4 $15.68
AXLE TO SPRING U BOLT NUT N805480-S426 use 8 $1.24
REAR SPRING B CODE SPRING 3C3Z-5560-CB use 2 $190.06
AXLE TO SPRING U BOLT N811667-S436 use 4 $8.94
AXLE TO SPRING U BOLT NUT*
N620485-S441 use 8 $1.99
The prices r what I found on an onlin dealer site.
#103
There are a set of Tapered blocks for sale for the V/B upgrade on Ebay which look like they may go pretty cheap. These are the ones you need I think.
3.5 inch tapered blocks for Ford Superduty - set of two | eBay
#105
Yep. X codes came on F-350's with the snow plow prep package for the extra weight up front from the plow, you are basically doing the same thing, hanging a bunch of new weight off the frontend.
timf150
08-29-2015 12:39 PM
Hunter,DDS
09-22-2012 01:48 AM
