Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 05:05 PM
rsav's Avatar
rsav rsav is offline
rsav is starting off with a positive reputation.
ABS works sometimes..
couple weeks ago I posted a message about my ABS not working. Some one suggested that I run the truck in the grass and lock up the brakes.Great advice, worked just like you said it would. Could feel & hear the brakes pulsing. Problem is, this fix only last for a couple days.The system works great when it works, but I have to reset in the grass ever few days. No ABS light, new pads all around, new tires, stock size. I drive on average,50 miles a day. Any suggestion what might cause this? Any help would be greatly appreciated. Thanks, Ro...
  #2 (permalink)
Old 11-06-2009, 08:17 PM
redford's Avatar
redford redford is offline
redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE.
Have you looked and or cleaned your VSS?
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73 LS Tow Command
Presently working as a military contractor in Afghanistan.
  #3 (permalink)
Old 11-06-2009, 08:58 PM
rsav's Avatar
Is that the sensor on top the rear diff? if so, no I have not, after reading a couple more posts I figure I'll do it 2morrow just 2 C. Thanks for you quick reply.
  #4 (permalink)
Old 11-07-2009, 08:44 AM
dfmatt dfmatt is offline
dfmatt is starting off with a positive reputation.
I have a 2000 model and I replaced the rotors and had the same issue. The parts stors sold me the wrong rotors. Check for a gear pattern inside rotors. My ABS sensor is on each of the front wheels reading a gear patern inside the rotors.
  #5 (permalink)
Old 11-07-2009, 09:18 AM
rsav's Avatar
Stock rotors, only changed the pads.Getting ready to head into the garage ang pull the sensor on the rear diff. Thanks for the tip. Is there a sensor for each wheel? My truck is a 4X4 .2003,6.0L....Ro
  #6 (permalink)
Old 11-07-2009, 12:11 PM
rsav's Avatar
Changed the VSS. NAPA part #530000, $16.31. now only time will tell.Thanks to all for your time. Will post in a couple days with results.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
