Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 05:03 PM
delmel delmel is offline
delmel is starting off with a positive reputation.
goofy gauge
anyone have a lead idea why the oil pressure gauge stops working?? For several months the gauge, while at idle, would jitter/quiver ardently. On pressure or throttle it would function properly. Now upon 'key on' the needle jumps to a bottom pint and is static, no movement whatsoever. I have had several highway travel drives since the problem and I do not believe the problem is in the oiling system??? Any experience or thoughts and recomendations.
Vehicle: '02 Mazda b-3000' Alias 'ford ranger 3.0'
Thanks in advance.
A
  #2 (permalink)
Old 11-07-2009, 12:00 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
Find the sending unit, and with the key in run and the engine off, pull the sending unit wire off and ground it to the engine block. The guage should swing full scale high or low. Then take the wire off the engine block and let it hang in the air. The guage should swing full scale the opposite direction. If it passes this test, the wiring and the guage are ok, and the sending unit is bad.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-07-2009, 01:16 PM
Smile goofy gauge
Hey Dave:
WOW! Thanks a bunch, I'll get at it today (hopefully) and have results soon. I greatly appreciate your help.
A
Tags
f150 , ford , gauges , guage , jitter , jittery , needle , oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
