Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 04:49 PM
cpt.phil's Avatar
cpt.phil cpt.phil is offline
cpt.phil is starting off with a positive reputation.
Restaurations pictures 1948 F1
The first pic . I bought this truck in Le Masa CA , however , he is already in Germany . He looks good but he was not. The last restauration was bad. I started completely restauration. next pics tomorrow
__________________
my toys are
1948 Ford F1 Pickup 1960 Porsche Diesel
1965 Unimog 411 1955 Lanz Bulldog
1974 Nimbus 2
  #2 (permalink)
Old 11-06-2009, 05:10 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
If you are doing a restoration, then will you be replacing that later model for 9" rear axle with an original? That angle iron crossmember behind the axle also did not come from the factory. For safety I'd suggest replacing the brake lines with ones the correct length and redo the flex line to the rear axle.
I see you are/did replace the engine with a porsche diesel engine. That's an interesting enginge choice, I doubt most of us even know porsche ever made diesel engines much less ever saw one. Tell us more about what the engine came out of, what type transmission you are using and add some pictures of the engine and where you are on the swap.
So you are actually doing what we call a "resto-rod", original looking on the outside with more modern running gear underneath. NICE!
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
  #3 (permalink)
Old 11-06-2009, 05:29 PM
BR F1 BR F1 is offline
BR F1 is starting off with a positive reputation.
I have two 1950 Ford F1 frames and both of them have a angle iron rivited behind the rear end. I believe it may be there to support the spare tire.
BR F1
  #4 (permalink)
Old 11-06-2009, 05:41 PM
AXracer's Avatar
I didn't think Ford used plain angle iron, I stand corrected! sorry!
__________________
  #5 (permalink)
Old 11-06-2009, 05:46 PM
cpt.phil's Avatar
For all guys, who don't know ,that porsche built diesel engines . This is a porsche tractor 1960
__________________
my toys are
1974 Nimbus 2
  #6 (permalink)
Old 11-06-2009, 05:53 PM
AXracer's Avatar
Is that the diesel engine you are using, out of a tractor??? That would really be unique!
__________________
  #7 (permalink)
Old 11-06-2009, 06:16 PM
cpt.phil's Avatar
No , not really . He get his flathead 6 back. The swap with porsche diesel engine was your misanderstanding.
__________________
my toys are
1974 Nimbus 2
  #8 (permalink)
Old 11-06-2009, 06:33 PM
AXracer's Avatar
OH, sorry your signature at the bottom of your posts says:
1948 Ford F1 Pickup 1960 Porsche Diesel so I assumed that meant you were putting a 1960 Porsche deisel engine in your truck.
__________________
  #9 (permalink)
Old 11-06-2009, 06:45 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is starting off with a positive reputation.
I second that angle iron. I have a 49 F1 parts truck and it's there as well.
__________________
1951 Ford F1 Panel
1952 Ford F1 Panel
1937 Chrysler Airflow C17
...and way too many Bonus Built parts...
  #10 (permalink)
Old 11-06-2009, 07:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
ALBUQ F-1 is gaining momentum as a positive member of FTE. ALBUQ F-1 is gaining momentum as a positive member of FTE.
Cpt. Phil, you must have high standards, that looks like a mighty clean truck! Even the back of the running boards looks solid, that is a "usual place" for cancer.
Ditto on the angle iron, the spare snugs up against it.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #11 (permalink)
Old 11-07-2009, 09:09 AM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
I had the same angle iron riveted on the rear of my 55 frame also.
__________________
Jaye
  #12 (permalink)
Old 11-07-2009, 09:46 AM
cpt.phil's Avatar
the next picture update
__________________
my toys are
1974 Nimbus 2
  #13 (permalink)
Old 11-07-2009, 10:27 AM
cbass139's Avatar
cbass139 cbass139 is offline
cbass139 is starting off with a positive reputation.
That look great, what do you have coating the brake lines?
__________________
"Nothing is particularly hard if you divide it into small jobs."
"Chop your own wood, and it will warm you twice."
-Henry Ford
  #14 (permalink)
Old 11-07-2009, 11:04 AM
cpt.phil's Avatar
synthetic resin varnish in a aerosol tin
__________________
my toys are
1974 Nimbus 2
  #15 (permalink)
Old 11-07-2009, 01:15 PM
dennisb56 dennisb56 is offline
dennisb56 is starting off with a positive reputation.
nice job, the frame looks great.
__________________
Dennis
52 F1
Coatesville, PA
Tags
1948 , 1952 , 1960 , 411 , dimensions , f1 , ford , images , nice , pic , pictures , red , truck , trucks , unimog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
