Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 04:45 PM
timhugg timhugg is offline
timhugg is starting off with a positive reputation.
problem of the week. no oil pressure on gauge.
Hi guys,
A little help please. Went to Advance Auto tonight to get some trans fluid. Came out and started the truck up no problem. Check gauge light went on. I look over and the fear of god went through me!! No oil pressure on gauge. I idled the truck home(less than a quarter mile) and shut her off. Seemed to run fine though. If I wasnt getting any oil pressure as the gauge was showing, wouldnt the truck not run at all because the injectors wouldnt fire? I am hopping it might be a sensor(EOP), but I dont want to spend the 35 bucks if its something else. Any help appreciated.
Thanks,
Tim
  #2 (permalink)
Old 11-06-2009, 06:14 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Check the oil level in the HPOP reservoir. If it is still full then you have oil pressure.
Make sure the EOP sensor connector is clean and tight. Also look for a broken or chaffed wire coming from the sensor connector.
Next step would be buy the sensor.
If the gauge still doen't register any oil pressure the gauge may be bad or not getting a signal from the PCM.
  #3 (permalink)
Old 11-06-2009, 07:59 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
As Robin pointed out, it most likely will be a sensor or gauge problem.
There are certain times when a LPOP is failing or becoming weak, and can provide enough oil to run the engine and supply the HPOP. At the same time, the HPOP is pulling so much oil, that the rest of the engine is suffering from lower than normal lube oil pressure. It's rare that it happens, but it's possible. Usually happens more often with a weaker LPOP and running a very strong aftermarket HPOP setup, since those use more oil than a stock HPOP would. There have been instances where people have made WOT runs with a weak LPOP and aftermarket HPOP, and have seen engine lube oil pressure drop to nearly zero!
Basically, you'll need to verify the oil pressure sensor and gauge is working. If those are in fact good, then you have an LPOP problem. Engine lube oil pressure has to drop pretty low in order for that dash gauge to drop (assuming the gauge and sensor are working properly). That dash gauge is almost like a dummy gauge, since it has such a wide "normal" range.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #4 (permalink)
Old 11-06-2009, 08:09 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
I'd say you're safe. No oil pressure means the injectors won't fire in almost all conditions. For those oddball situations we have Curtis. Now if you will excuse my hijack.
Quote:
I can see how this would be possible, but it seems like the stars would have to be aligned just right for that to happen, since just a hair more demand ICP would result in noticeable power drop off.
This sounds more like an improper upgrade (not addressing an improved LPOP) than anything else. Have you seen a consistent line of mods that esulted in this situation? At what point is the upgraded LPOP something that should be included?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #5 (permalink)
Old 11-07-2009, 01:13 AM
Pocket's Avatar
No you are correct, it's rare, and things would have to be just right to have this happen (stars in alignment, fingers and eyes crossed, stick out the tongue, turn 3 times, clap your heels together, and say "there's no place like home").
Because it's rare, it doesn't consistently happen with any particular mod. The only thing that can be seen on a more regular occasion is a slight drop in oil pressure with really big aftermarket HPOP oil systems. On my truck with twin pumps, I'm willing to bet that I can get engine lube oil pressure to drop slightly on a WOT run. However, my dash gauge won't budge, so it's not dropping enough to raise any alarms or concern (at least for me).
If the LPOP is bad, and it's pumping just barely enough oil to keep up, a majority of that oil will be sucked up to the HPOP reservoir simply because it's the path of least resistance. Whatever is remaining will go to engine lube oil, which would account for the drop in lube oil pressure, yet still have the engine running.
But, it is a very rare occasion, and the LPOP has to be pushing out just the right amount of oil to make that happen. Enough to keep the HPOP happy, but not so little that the engine stalls. For the OP, first thing is to check sensors and gauge, and make sure they are accurate.
And I probably dropped the hammer too soon by mentioning that as a possibility earlier. Easy stuff needs to be ruled out first.
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #6 (permalink)
Old 11-07-2009, 09:32 AM
the engine on this truck is all stock, no aftermarket hpops and the like.
  #7 (permalink)
Old 11-07-2009, 10:25 AM
The weekend is saved fellas!! Just put in the new EOP sensor from napa and gauge is working again. Hope this post helps someone in the future.
Huggmeister
  #8 (permalink)
Old 11-07-2009, 10:42 AM
PaysonPSD's Avatar
Support FTE
Thanks for getting back to us with the fix and I'm glad it was an easy one.
Tags
73 , ford , guage , low , oil , pressure , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
