What kind of oil in DANA 21 transfer case
Hi!
I hope U understand my poor English, I`m from South of sweden.
My Q is..............
What kind of oil shall it be in my Dana21
I filled it with axel oil 80/90 but 76oil in sweden recomend ATF.
I filled it with 80/90 because the old oil was axeloil.
(U don`t need to be a rocket researcher to find out that it was not ATF oil)
It`s a kind of rare car in sweden.
USA built working cars are often Dodge or chevy in sweden.
Here is a pic, its no beauty. But it`s all mine and I like it..........
It`s a Ford F100-75 390cui 4 on the floor 38,5" tire
[/IMG]
Check out
powermeet in Sweden.
[/IMG]
Check out
Code:
http://www.bigmeet.com/index.php
Its as beautiful as can be,
Regular gear oil is the reccommended oil for your transfer case. ATF is too thin for this application. ATF is used for later BW aluminum transfer cases. Your gear driven transfer case had 80-90W gear oil in it from the start and thats what you should put back in.
67-F100
05-14-2013 01:06 PM
Newcomer
Offroad & 4x4
50
09-02-2011 02:55 PM
21, case, dana, ford, fordtransfercasegearoil, gear, kind, oil, pic, put, spec, transfer, transfercase, transfercases, wat
