__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
♠ Real Trucks Don't Have Spark Plugs.♠
There is a switch in the master cylinder that has battery power at all times.
If the switch fails, which can happen when no one is around and the vehicle is not running, a fire is the result.
I know of two vehicles lost that way close to me, one being my friends, and the other was an E series that took the house with it as well since it was parked in the basement garage.
What I can't figure out is why they have battery power running to that switch at all times.
Cruise control surely don't need power when the engine is not running.
Only vehicles with cruise control have that switch.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
I am going down to the dealer on monday if I get the truck on the road by then. I sure dont want my truck to burn up on me. I was actually suprised to see the letter in the mail already since I only bought the truck 3-4 months ago.
__________________
Tearin' down a dirt road Rebel Flag flyin and a coon dog in the back. Truck bed loaded down with beer and a cold on in my lap -- If you got a problem with that you can Kiss My Country A**
Look at your master cylinder, there ia a pressure switch on the side with two wires on it.
One has battery voltage constantly, can't remember but I think it may be yellow.
Unplug that wire till you get to the dealer.
Your cruise won't work, but your truck won't burn either.
__________________
Im disconnecting my batteries for now. Its not like I am driving it w/o a driveshaft.
__________________
__________________
if my donor truck for the body was a 94 and the steering wheel has cruise buttons, should i worry about this? I doubt it is an issue but i am not sure. Thanks fellas.
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
Is there any way to fix the issue and still have cruise? My dad has 3 trucks under that recall, and he would really hate to have no cruise.
nah,you wont loose your cruise.
they just place a short wire with a fuse that will blow in the very,very rare event that the switch leaks brake fluid internally and or happens to run down on the abs block down below,and then that has to be hot enough at the time to make the brake fluid start to smoke.then it has to be good and hot to actually lite her up in flames.
but,hey.it happens or they wouldn't recall 'em right?
anyway.you can take it in,and they will put a little fuse so it pops and stops the current in an event of a brake fluid leak from that switch.
or,you can do it yourself if you rather,but there's no cost.(well,of course nothings free,or ford would be out of business too lol.they have to make up for lost revenue on recalls somewhere.i think i'l just test for the hot wire,and put a fuse in myself.)
disregard the old deadline date from this one: http://www.wxyz.com/media/lib/87/3/6...r_to_NHTSA.pdf
__________________
