Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 03:14 PM
Imdok Imdok is offline
Imdok is starting off with a positive reputation.
Help with Fuel/Carb Problem
Hi folks,
I'm have a problem I can't quite figure out and would appreciate any advice you'd be willing to give me.
First off, I have a 1982 F-250 with the 4.9 300 Inline 6 motor with single barrel Carter carburator.
A while back I noticed it was starting to take a longer starter turn time for my truck to start and then a lot more foot pumping on the accelerator to get it to start. It finally got to the point where it wouldn't start at all if the truck had sat for more than a day without it being started.
I'd pour a very small amount of gas (less than a thimble full) into the carb throat and it would start fine and run all day doing errands and shutting it off and restrarting etc. with no problems restarting it (still works this way). It usually would start the next morning but if I didn't use it that day it wouldn't start the next day after that.
Somebody said it sounded like the ball check valve in the fuel pump was allowing the fuel to seep back into the fuel tank (don't know if this guy was full of it or not) so I put a new fuel pump on truck. That wasn't the problem (I should have checked the old fuel pump first).
I also unscrewed the fuel line where it goes into the carb and made sure that little housing thing(filter?) that screws into the carb, with the fuel line going into it, wasn't plugged by blowing through etc.
I'm out of ideas. We rebuilt this carb a couple of years ago and it hasn't gotten that much use and has always ran fine since then (accept for some automatic choke problems we fixed by installing a manual pull choke setup)
Like I said earlier, All it takes is a few drops into the carb throat and the truck starts and runs fine all day with multiple restarts and stops. It's a pain to have to open the hood, unscrew the cleaner housing lid and put a few drops into the carb. It will be even worse now that winter is here.
Could it be the accelerator pump (do these single barrel Carters even have one?).
Any ideas would really really be appreciated. I'm fairly rural in Alaska so I have to do things for myself for the most part.
Thanks
__________________
1982 F250 4x4 300 ISix w/ 1bbl carb, 4speed granny tranny, 354 diff gears, Leer canopy, Boss snowplow
  #2 (permalink)
Old 11-06-2009, 05:42 PM
86bigred's Avatar
86bigred 86bigred is offline
part time
86bigred is starting off with a positive reputation.
I have seen this before.there is a rubber valve that works with the acclerator pump.what's happening is the fuel is leaking out and when you crank it over you have to fill the carb again.a carb rebuild should helpand they are cheap as well.
__________________
81 f150 302 4 sp od daily driver
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
http://s469.photobucket.com/albums/rr57/86bigred/
Tags
1980 , accelerator , adjustment , ball , barrel , carburetor , carter , check , f100 , ford , gas , issues , leaking , pump , single
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
