North Carolina Chapter Join Chapter, Leader:Benztechnc
I-Beam Alignment
Old 11-06-2009, 01:52 PM
Metallheadd's Avatar
Metallheadd
Metallheadd is offline
I-Beam Alignment
Does anyone know a good shop to get a frontend alignment on an IBeam 2WD Ford? Im near Statesville so a 50 mile radius would be good. Thanks
Old 11-07-2009, 06:26 PM
Metallheadd
Anyone?? I know most places wont mess with the beams.
Old 11-11-2009, 03:09 PM
fuzzy1626's Avatar
fuzzy1626
fuzzy1626 is offline
Ford stealership?
Old 11-12-2009, 05:47 PM
Metallheadd
I got a price today $59.95 + $30.00 per bend. is that high or about right.
Old 11-15-2009, 04:52 AM
jowilker's Avatar
jowilker
jowilker is offline
Are you sure your axle is bent??
John
Old 11-15-2009, 10:11 AM
Metallheadd
No but I am getting heavy wear on the outside edge of my drivers side tire. About an 1 1/2" wide area.
Old 11-15-2009, 05:29 PM
jowilker's Avatar
jowilker
jowilker is offline
You have had the toe set??
Whether the price is good or not, seems that that the above mentioned is the only place that you have found. Usually a tire shop that also deals in truck tires can do the I-beam bends. It is just unusual for an I-beam to be bent.
John
Old 11-15-2009, 05:55 PM
Metallheadd
Is it? ok, well I have only ever had one other I-beam ford aligned but it was hit and definitly needed a bend. I guess I will take it in and see. No I have not had the toe adjusted.
1961mike
20
02-23-2023 08:15 AM
72CC428
23
11-26-2017 08:49 AM
I_Thnk_Ford
General Automotive Discussion
21
06-08-2015 11:07 PM
ALedbetter1
Missouri Chapter
02-28-2014 11:57 PM
j-marr1
12-16-2013 03:28 PM
Quick Reply: I-Beam Alignment
