I-Beam Alignment - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
I-Beam Alignment
Old 11-06-2009, 02:52 PM
Metallheadd's Avatar
Metallheadd Metallheadd is offline
Metallheadd is starting off with a positive reputation.
I-Beam Alignment
Does anyone know a good shop to get a frontend alignment on an IBeam 2WD Ford? Im near Statesville so a 50 mile radius would be good. Thanks
Old 11-07-2009, 07:26 PM
Anyone?? I know most places wont mess with the beams.
Old 11-11-2009, 04:09 PM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is gaining momentum as a positive member of FTE.fuzzy1626 is gaining momentum as a positive member of FTE.
Ford stealership?
Old 11-12-2009, 06:47 PM
I got a price today $59.95 + $30.00 per bend. is that high or about right.
Old 11-15-2009, 05:52 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Are you sure your axle is bent??
John
Old 11-15-2009, 11:11 AM
No but I am getting heavy wear on the outside edge of my drivers side tire. About an 1 1/2" wide area.
Old 11-15-2009, 06:29 PM
jowilker's Avatar
You have had the toe set??
Whether the price is good or not, seems that that the above mentioned is the only place that you have found. Usually a tire shop that also deals in truck tires can do the I-beam bends. It is just unusual for an I-beam to be bent.
John
Old 11-15-2009, 06:55 PM
Is it? ok, well I have only ever had one other I-beam ford aligned but it was hit and definitly needed a bend. I guess I will take it in and see. No I have not had the toe adjusted.
KING PINS 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 15 01-12-2017 02:07 AM
Homemade I-beam alignment tool? I_Thnk_Ford General Automotive Discussion 21 06-09-2015 12:07 AM
1966 frod f100 front alignment 1961mike 1961 - 1966 F-100 & Larger F-Series Trucks 14 03-02-2015 10:14 PM
Where to get an Alignment in the Springfield area ALedbetter1 Missouri Chapter 2 03-01-2014 12:57 AM
Late model I-beam swap j-marr1 1967 - 1972 F-100 & Larger F-Series Trucks 7 12-16-2013 04:28 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1976, 2wd, align, alignment, beam, bend, bending, end, f100, f250, ford, formula, front, ibeams, obs, prices, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
