Just a few curiosity questions. Do the OBS 97 trucks have split shot injectors (AB). If so, do they have a different driver module, do the 99-03's have different driver modules to run the split shots? Also, what year is the best year to look for to do the driver module mod (i forget the acronym)? I have heard the 94 and 95s are the best, but I don't know. I would like to get my hands on a spare and mod it, and then test the two and see if there is much of a difference.
The 1997 Cali models did have split shot injectors. All others had singles shots.
If you are talking about the IDM (injector drive module) the '94 - '97 had the same at 90 volts.
The '99 - '03 had 120 volts.
If you do the "IDM mod" then that changes it to 140 volts.
So it doesn't matter which one you choose to mod ('94 - '03) you will end up with the same result. 140 volts.
This is from forgotton:
IDM-100 uses a 75.0k Ohm (75,000 ohm) 1/2 watt 1% tolerance Metal Film resistor
IDM-110 uses a 75.0k Ohm (75,000) 1/2 watt 1% tolerance Metal Film resistor
IDM-120 uses a 73.2k Ohm (73,200) 1/2 watt 1% tolerance Metal Film resistor
so IIRC there are not IDM 90 volts.
something about that. what would the 110v IDM go into???? not the SD and not our trucks so i don't think there was a 110v, but there was a 90v.. LoL. idk about the 100v either. never heard of those 2. 90v, 120v, then the modded 140v is all i know about
The IDM number is the volts.
The early PSD's started with 100 volt, then they went to 110 volt sometime in '95 I think.
The SD in '99 went to the 120v.
There was no 90 volt IDM.
Any IDM will run any 7.3 PSD, but the higher the voltage the better.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
Thanks, JIM, saved me of typing that.
Sorry TRAVIS. and blue66
I asked that question awhile ago. I do not remember the reason but the answer was not to do it. Stay at 140v. Now if somebody know something else, I am all ears.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <>< 95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v 2000 Ranger 4X4 No MODS, yet!
The electronics guys that build my flow bench controller (which uses an IDM) said they beilieve it's possible to bump to 160v (which is very easy to do) but they are not sure how long the rest of the components would last. It might be seconds, hours or thousands of hours of run time. Nobody has tried, too much $$$ to mess up. 140v is very reasonable as far as the rest of the stuff goes, but 160v is just pushing it.
Also, there comes a point when the solenoid/Poppet might just not react any quicker. 140v might be all it takes to make them as fast as they will be. Not sure...
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
