I did it. I took an 86 F150 2wd and put it on a 77 150 4wd frame. quite a bit of work.
had to make new front cab mount frame perches and Radiator mount perches.
I had quite a bit of trouble getting the wheel wells center right. The gap between the cab and box was a little more than I wanted.
Probably the best 86 4wd ever, but I wouldn't do it again. I am currently doing a similar project but with a 79 2wd body on a 79 4wd frame.
If I can find some old pics i'll try to scan them in this week end.
Shawn
__________________
'65 F-250 4x4 w/ '76 460 & 514 in a 1900lb Drag Rail
Under construction: "Black & Bad" '79 F-150 4x4 -351w, 435np, 205np, TFS Twisted Wedge heads, Speed demon, Comp 4x4 extreme cam, edelbrock RPM AirGap, NOS Powershot, detriot locker, w/a '73 grille
