99 Ford Ranger Troubleshooting question - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-06-2009, 12:08 PM
cliftonfts cliftonfts is offline
cliftonfts is starting off with a positive reputation.
I have a 1999 Ford ranger 4.0L EFI 4Wd
Here is the a link to the values I was receiving with a OBD scanner . I got trouble codes PO171 and 174 running lean on banks 1 and 2. I have recently in the past few months change MAF sensor, 2 O2 sensors, fuel filter and air filter and spark plugs. I even tried checking for a vacuum leak by spraying carburetor cleaner around the engine to see if it idles higher. But I can't seem to find a vacuum leak. Thanks for your help.
cliftonfts' Home Page - Road Runner Personal Home Pages
Old 11-06-2009, 08:11 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Check the wiring on the transmission.
P0171 and P0174 are both fuel system DTC's The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
Possible causes are Fuel system, Excessive fuel pressure, Leaking/contaminated fuel injectors, Leaking fuel pressure regulator, Low fuel pressure or running out of fuel, Vapor recovery ststem, Induction system, EGR system, Base Engine.
Old 11-06-2009, 08:18 PM
Helm Inc has the Powertrain Control/Emissions Diagnosis Service Manual available for the 1999 Ranger, you can rent it for 72 hours for 10.95, buy the paper copy for 180 (it's worth it).
Old 11-08-2009, 02:07 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Add the PCV valve to your suspect list, especially if it's due, or past due, or hasn't been changed for a while. if it's sticking open, it'll cause a non-planned for vacuum leak!!!!
Poor idle and code P0171 and P0301 - PCV valve elbow? carpe_diem Ranger & B-Series 5 01-05-2015 03:22 PM
1999 Ford Ranger lacking power tim_cleav Ranger & B-Series 6 09-12-2013 02:59 AM
Runs Rich High Idle No Power PCM? 87f250banks Ranger & B-Series 19 04-02-2011 10:03 AM
P0171 code wheelchairdude49 Ranger & B-Series 14 01-19-2011 11:27 PM
Intake Plenum Gaskets Codes P0171 & P0174 Gulliver Ranger & B-Series 13 03-21-2010 10:34 PM
Tags
2000, 4wd, 99, code, codes, filter, ford, fuel, list, maf, p0171, p0174, ranger, trouble, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
