I cant give you a definite answer, but my 11-15-02 build date had 4 threads. Let us know what you find and we will be able to get a better cut off date for more threads.
Will do. I keep putting off the plug change until I figure out my driveline vibration. I have already sunk some$$ into fixing it, but haven't found the problem yet. If I can't figure it out, I do not see myself keeping it as it drives me absolutely crazy to have driveline vibes with nothing more than F350 blocks. Heck, it had vibes stock. I am getting ready to replace the transfer case. If that takes care of the vibes, my next job will be the plugs. Funny, I would rather change a transfer case than do plugs on a modular.
__________________
91 Mustang GT 5.0L 302, 5 speed, 4.56's, .616 solid roller, Pro Topline heads, etc. 8.09 in the 1/8th 3100lbs
03 Excursion V10 4.30's , V codes, 350 blocks, 305's, Monroe Reflex's, dents and vibes
09 Jeep Wrangler "X" Unlimited
I have never looked under an excursion but does it have a 2 piece drive shaft with a carrier bearing? I had to shim mine down stock to get rid of a vibration then even more down when I put the 350 blocks in.
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
I think, but not sure, that all 5.4's are also produced there, with the exception being the 4-valve 5.4's that are produced at the Romeo plant.
__________________
