Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-08-2009, 12:49 PM
Scot Scot is offline
Scot is starting off with a positive reputation.
See my gallery.
__________________
'78 F250 4x4 Supercab, Cummins 6BTA, NV4500, South Bend clutch, NP205, Dana 70/60.
'55 F100. 302, Tremec TKO, 9" 4.11 LSD, A/C P/S, disc brakes, cruise, arrest-me red.
  #17 (permalink)
Old 11-09-2009, 07:49 PM
alans77crew alans77crew is offline
alans77crew is starting off with a positive reputation.
I really thought about puttin a 7.3 in but all computer controlled and more hassle.all it takes for a cummins is a 12volt wire! and they do put a cummins in a 450 no bigger than a one ton except springs and ford also has an interest in cummins so why not! and boys it's already in the works found a whole truck with a 5 speed 3200.00 has 169,000 on and original owner so now come's the hard part convincing momma!!!! wish me luck gent's!
  #18 (permalink)
Old 11-09-2009, 09:42 PM
gstanfield's Avatar
gstanfield gstanfield is offline
gstanfield is starting off with a positive reputation.
Dont worry about it not being a "ford" engine. As far as it goes the navistar 6.9/7.3/6.0/6.4 diesels used in fords are not "ford" engines either. Think of it like over the road trucks. You pick the chassis you want, then add the engine and trans of your choice.
George
  #19 (permalink)
Old 11-10-2009, 12:00 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
FINALLY - someone who gets it!!!!!
Guys always give me grief about the cummins saying stuff like "built ford tough with dodge parts" to which I typically reply something like the following:
That cummins motor is NOT a dodge motor. Cummins makes motors and people/companies contract with them to put them in everything from industrial generators to boats. Do you go give the guys in the harbor grief for running a "Dodge" motor in their boat
Also - good point on the "Ford" diesels. Sometime the die hard guys saying "keep it ford" need to get a clue
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #20 (permalink)
Old 11-10-2009, 09:21 PM
460swmo 460swmo is online now
460swmo is starting off with a positive reputation.
Quote:
Originally Posted by alans77crew View Post
Ok let me start out with this ,I know a lot of you out there love your 351/400's! I don't I love the small blocks302/351w and the 429/460! So I'm not gonna rag about them to much,but I bought a 1978 f250 supercab 60's front and rear 4 speed all in all a good truck 32,000 on a NEW 400 ! well when I got it it ran like a turd! so I fixed all the dumb ass things he did and got it running pretty good. Well all was well till the other day started running like crap after about a 20 mile drive checked all the obvious things nothing! so here's my question 460 or 12 valve cummins I have a dove-a block and heads that I can build or I can buy a donor truck for the cummins I'm leaning toward the cummins for mileage and power I tow a 26 foot camper a lot ! I know the power of a 460 is awesome but the problem I've always had was in the trans the 435 has to much split between 3rd and 4th and they fall on there face on a pull ! I'd really like a 5speed and a cummins you guy's let me know what you think!!!!
Use the 460 but do it with a 4.3 stroke crank which works great in a truck. The 385 series Ford engines are some of the best engines ever made and this swap is the most common, so common many companies sell whats needed to do it easy. Plus the truck is worth more with the Ford engine. The site 460Ford.com is a good site with many expert builders of these engines. A 1988 thru 1997 fuel injected truck 460 might be a good choice to consider also, they commonly out last the rest of the truck.
  #21 (permalink)
Old 11-10-2009, 09:34 PM
bassdude bassdude is offline
bassdude is starting off with a positive reputation.
you're simplest least expensive swap is going to be a 460. stick a five speed behind it and you'll get OK MPG's. I've got a 460 and NV4500 in my scout and i get 15 on the highway.
__________________
  #22 (permalink)
Old 11-10-2009, 11:46 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Quote:
LOL, they are idiots. The ONLY reason the Dodge Ram was popular is because of that Cummins. The dodge truck is just a candy wrapper.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #23 (permalink)
Old 11-11-2009, 12:30 AM
ford1977owner's Avatar
ford1977owner ford1977owner is online now
ford1977owner is starting off with a positive reputation.
with reading about u towing alot id say go with the cummins
  #24 (permalink)
Old 11-11-2009, 08:15 AM
jimlj jimlj is offline
jimlj has a good reputation on FTE. jimlj has a good reputation on FTE.
Quote:
Yup, I tell them I pulled the diamond out of a goats azz and put it where it belongs
__________________
'79 F250 4X4 Super Cab, Dana 60 front and rear, Cummins Turbo Diesel, NV4500 transmission, NP 205
'06 F250 4X4 V10 Super Cab
'57 F250 rust pile
Bitter American clinging to his guns and religion.
  #25 (permalink)
Old 11-11-2009, 11:52 AM
1974 Ford F-250
Quote:
You sure about that? I see trucks with cummins swapped in going for more than ones with 460's. Of course it depends on the overall condition of the truck - but an apples to apples comparison with the only difference being 460 or cummins and my $$ is on the cummins truck bringing more cash all day long
__________________
1970 Ford F250
Tags
1970 , 1977 , 1999 , 2002 , 390 , 460 , 4x4 , 73l , engine , f100 , f150 , f250 , ford , swap , swaps , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
