I have a 1990 bronco II 2.9 4x4. Recently I just replaced all my fuel injectors to increase my fuel performance. After i put everything back together I noticed that my temperature gauge no longer works it stays pegged at below zero. Before the injector change it worked fine. I have since replaced the temperature sensor and confirmed that the wires connected to the jack were still ok. I tested the old temp sensor and it appears to work ok. testing resistance I see a resistance change the hotter it gets. After all this my gauge still does not work. Does anyone have any idea as to why this would suddenly just stop? Any suggestions?
