Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 10:51 AM
1980F15049's Avatar
1980F15049 1980F15049 is offline
1980F15049 is starting off with a positive reputation.
Removed smog.. More or Less power?
Hey there.. (1985 Bronco XLT 351W Carb) I removed my smog pump and all associated stuff including egr(replaced intake and carb). Plugged heads. I never drove my truck with smog attached.. Does the truck have more power with smog or less power?
  #2 (permalink)
Old 11-06-2009, 11:17 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
It won't make any difference unless some part of what you removed was leaking or malfunctioning badly. Some of the carbed motor also have a stupid butterfly valve in the passenger side exhaust right after the manifold that often seizes partially closed, if that happens there will be a severe loss of power.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 11-06-2009, 05:38 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Quote:
That there "stupid butterfly" has been around long before the smog equipment btw. Just to make it clear that it's not an emissions item. Called a "heat riser", it blocked one side of a V8 to force exhaust through passages in the intake manifold when the engine was cold. They often froze up. Examples, my dad's '58 F600 with a 292 had one, a family friend's '60s FE equipped Custom and Galaxie sedans had them. As a result in those cars, the right side exhaust rusted out in 1/3 the time as the left. I think my '65 289 Mustang had one too.
  #4 (permalink)
Old 11-06-2009, 07:22 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Conanski is right here. If you remove the smog pump and emissions equipment the only real gain in HP is from not having those accessories being driven by the belt/belts anymore... which is next to nothing because most of the HP loss from accessory drive starts with the power steering pump, and then the water pump..... so its next to nothing you gain from not running it.... just make sure it functions properly so you don't lose power.
  #5 (permalink)
Old 11-07-2009, 10:48 AM
1980F15049's Avatar
Disconnected that buttery fly and tie wired it open until I get headers..
Tags
302 , removed , smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
