Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 10:00 AM
Stumpalump's Avatar
Stumpalump Stumpalump is offline
Stumpalump is starting off with a positive reputation.
Disabling a V10 for anti-theft
I was wondering if you have any simple sugestions for making my rig theft resistant. I'd like to just unplug somthing so it can't be stolen. I temporarrraly have to park it in Phoenix where auto theft is high. What connection would you disconnect?
__________________
1979 F350 4x4 SC 460 ci SM465
2008 Ford Edge 265 hp 3.5L Daily driver
1951 Ford 8N Tractor
2002 E350 4x4 V10
  #2 (permalink)
Old 11-06-2009, 11:34 AM
zooom zooom is offline
zooom is starting off with a positive reputation.
What to unplug...?
Assuming you realize that if someone wants your ride badly enough, he/she's gonna get it: just try disconnecting the negative battery terminal under the hood.
Only negative price you'll pay with this approach is the temporary loss of radio stations, trans info & similar -- but these are easily "re-learned" once you reconnect & drive away [takes ~10 miles to relearn the trans info]. But the approach is quick & only requires a 10mm wrench to accomplish....
  #3 (permalink)
Old 11-06-2009, 12:29 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Pull the fuse to the fuel pump. Look in your owners manual which fuse is for the fuel pump and pull it. When you return put the fuse back in and be on your way. Just put the fuse someplace where it can't be seen and you only know where it is.
__________________
FS: Factory Tech Valve Body for 4R100 http://www.ford-trucks.com/classifie...ct/27799/cat/5
69,873,761 firearms owners killed no one yesterday....
  #4 (permalink)
Old 11-06-2009, 02:13 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Quote:
Underhood in the high-amp fusebox, there's usually a fuse for the PCM. Pull it from that slot,and just move it to another unoccupied slot so it's where you can get to it and not lose it. No power to the PCM=no start,no matter what they do.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #5 (permalink)
Old 11-06-2009, 08:03 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life is gaining momentum as a positive member of FTE. Fordfanatic4life is gaining momentum as a positive member of FTE.
make urself a dummy fuse...
put it in place of some required fuse to run the truck..
that way even if they look in the fuse panel they wont see anything mising...
__________________
2003 F250 4x4 CC V10 4" Procomp, all white beauty
"list of previous owned Fords much to long to list here.."
  #6 (permalink)
Old 11-07-2009, 04:31 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Quote:
That's what I do when I don't want it to start. Johnny is right too, pull the PCM fuse, same result.
I doubt any thief is going to go under the hood looking at fuses when they can't get the truck to start. They MIGHT, but ... doubtful.
For my '96 t-bird, or '97 cougar, I reach inside the trunk area, behind the mat inside the left fender, and pull the connector for the inertia switch.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #7 (permalink)
Old 11-09-2009, 03:32 PM
marcussen marcussen is offline
marcussen is starting off with a positive reputation.
How good are the new micro chiped keys, I didn't think the PCM would let it start without the special key in the ignition.
__________________
It takes hundreds of nuts to hold a truck together, but it takes only one of them to scatter it all over the highway.
2008 F250, CC, Black, Lariat
Single Rear Wheels (4x2), Long bed,
Torqshift transmission, V-10 - 6.8L
4.10 Limited Slip
  #8 (permalink)
Old 11-09-2009, 03:42 PM
2005 Ford F-250
Quote:
F-Series prior to '08 and the E-Series DO NOT use the PATS system.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #9 (permalink)
Old 11-10-2009, 09:22 AM
I was just curious the 2008 model have PATS, but I don't know if a thief can bypass the system. I searched the web but I can't find any information on how effective the system is. Searching this website it looks like these trucks are easy to break into. The idea of using the keypad on the door and locking the key inside defeats the best part of the antitheft system. ( I do this at the lake etc.)
__________________
4.10 Limited Slip
  #10 (permalink)
Old 11-10-2009, 09:25 AM
2005 Ford F-250
The PATS system works very well-the PCM WILL NOT allow the engine to start unless the correct key is in the ignition. Not just inside the vehicle,in the ignition switch. The proximity sensor for the PATS system is a very short range device,and looks for the key's transponder at the steering column. No transponder key=no start.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
Tags
2000 , antitheft , disable , f250 , ford , fuel , pats , phoenix , thefts , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
