__________________ 1984 f250 6.9 idi diesel 4x4 with a borg warner t19 4 speed manual with a granny gear, 7.5" western unimount plow... ROLLIN' COAL!
'96 F350 crew cab XLT dually 2wd alcoa wheels 7.3 PSD E4OD ,300,000 miles+
64,999,987 firearms owners killed noone yesterday. protect our second amendment
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
but it looks like those blocks are reinforced and your just jealous its bigger than yours.lol
__________________
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990 ... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
I would not try to drive that to the end of my driveway.
If that went through an inspection station here they would impound it.
And although there is not a picture showing the rear suspension, I thik it hass the same fine engineering back there as well.
"Lots of time and money went into making this truck the way it is. This Truck is really fun and it draws looks wherever you go. I drive it back and forth to work every day and it runs fine. I have never been able to get this truck stuck either. There is nothing wrong with this truck other than the fact that the tires need to be balanced b/c no one around here can do it."
Hard to get stuck on blacktop, the drive shafts would surely fall out if you took it off road.
To bad all that money was wasted, Joe you should post that link in the off road forum, I can hear the comments now.
Never put lift blocks on the front axle of a road driven vehicle.
I can't imaging the stress that the U bolts would be under in a panic stop.
If you ever hit anything the rear tires would be driving over the front tires.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
And to imagine; he thinks the vibrations are coming from the tires...
__________________
Jim
____________________________________
1987 F-250 4x4, 6.9 ATS turbo, 4 spd
1993 Lincoln Mk VIII, coil spring conversion, 4.6l of fun
Dave, I think the tie rods would snap before the drive shafts.
Look at the stress on them!
__________________
The tie rods should be able to handle more rotation than it would take for the drive shft slip joint to come apart.
With big tires like that axle wrap becomes an issue rather fast.
That is why the serious off road trucks runnning tires in the 36" and up tire sizes lay out lots of money for parts to build three or four link suspension setups to keep the U joints from being broken as the axle twists without them.
With 12" blocks between the springs and axle, that wrap would turn into the axle moving forward more than the length of the splines in the driveshaft on the front axle while the rear axle is getting the drive shaft jambed together when going forward.
Hard braking or reverse would move everything the other way.
I do agree, the steering linkages turning that much rubber are under huge loads, and the custom bends in the drop link make it weaker.
Just think, he drives it on the road every day.
Won't that make you feel real safe every time you meet a truck jacked way up with big tires under it out on the highway now?
This is a non highway driven truck, and if you look at the rear axle you can see the drive shaft and two of the links I am talking about going in front of the telephone pole.
You can also see the vertical plates on the axle that go up to the top link which is orange.
The axle can move up and down, but not twist at all because of the links.
Same setup on the front axle so it can't twist either.
Those are 54" tractor tires on Rockwell axles with Lincoln lockers in both axles, which I have seen stuck.
__________________
