Quote:
If you wanted to use quick disconnects, for the pump power I would use a large plug like they use on forklifts, and count how many smaller wires you need to unplug, and possibly a 6 pin trailer plug would work for that.
I plan on buying this kit and an extra pigtail ( the part circled) to attach to the pump:
I want the part permanently attached to the truck switchable instead of always on.
Then I only need a plug, like the 6-pin trailer plug, for the headlights and turn signals.
The hydraulic valves are underhood, so I just need to disconnect the lines.
