You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
WTB 2008-2010 PSD F-350 OEM fuel door/Filler deck/neck and tubes, etc.
Looking to buy, for a reasonable price, 2008 to 2010 PSD Excursion, F250 or F-350 OEM fuel door + filler deck + filler neck with attached OEM Cap, filler and vent hoses, inside and outside walls also needed, Diesel fuel only.
Take a Sawz-all or torch cut and leave about 6" of bed wall (inside wall and outside wall) all the way around the fuel door, also need the complete filler deck/hoses and OEM Fuel cap/door, all hoses to the fuel tank (Diesel only).
Have Pay Pal account.
Tia,
Don
__________________
"Any Elected Offical that fears me owning a Firearm, Then I fear that Offical"
2010 Publeo Gold Metalic,XLT F-350,6.4 PSD,4x4,CC, SRW,SWB,3.55LS,6 spd Manual,Tow,10,000#Spring package,50 gal bed tank,Caravan Camper shell, Ravelco Anti Theft,Seat covers,Mud Flaps,HD Floor mats,Running boards,Linex Bed Liner, Dob: 11/10/09
2007 28KS Desert Fox TH, 14,000 Equalizer WD Hitch
Reason: Found new info
Does this have the rear part that the filler neck/hoses attaches too with the three screws? Is this for a diesel fuel rig?
I need the door, inside fuel cap/threaded area, the backside where the hoses from the fuel tank attach to the fuel door area.
I am adapting this fuel door to a steel camper shell, I want to be able to open the door, take off the fuel cap and fill the reserve bed tank without crawling inside the camper shell every time I need to refill the tank.
Thank you,
Don
__________________
It is only the metal circle and the hinge attached to it. A billet fuel door was added to the rig and this is what it replaced. None of the hoses or housing. It came off a 2000 Excursion V-8 gasser.
I am looking for a Diesel set up, I never thought of the Excursion PSD fuel system. I guess that it would be basically the same set up, if my information is correct.
Any Diesel tank setup from a 2005 - 2010 Excursion,F-250 or F-350 would probaly work, as long as I get the wall with the door, fuel cap and threaded section and deck and would like to have the hoses down to the tank etc for this conversion etc.
Thank you,
Don
__________________
