Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 04:17 AM
justinfown1's Avatar
justinfown1 justinfown1 is offline
justinfown1 is starting off with a positive reputation.
Lightbulb valve lash / reinstalling cylinder head
1964 F250 4x4 262 inline 6 with T-98
finally getting everything buttoned up and will hopefully be starting the truck back up again this weekend.... in the service manual under installing a cylinder head, after you have everything installed it says to preform a preliminary lash adj. , now i have already done that, my question is.... do you re adjust after you fire it up? some people have said to tighten the rocker arms until there is no more play and then turn another 1/4 to 1/2 turn, others to start it up and back off each rocker till it makes chatter then tighten it till it is quiet and then 1/4 or 1/2 turn after that...... don't know if this applies to engines with solid tappets not hydraulic lifters???? this also doesnt sound right to me because in the service manual it says that the valve lash should be .019 hot/cold ..... wouldnt tightning down till there is no play be 0 lash?
anyways just want to be sure before i button up the valve cover and have to rip it back off to do more adjustment..... thanks!
  #2 (permalink)
Old 11-06-2009, 09:48 AM
tinman52 tinman52 is offline
tinman52 is starting off with a positive reputation.
262 has solid lifters....... you MUST set the lash with a feeler gauge or it won't run. They may make a little noise, just because they are solids........t/m
  #3 (permalink)
Old 11-06-2009, 08:25 PM
thanks t/m so since i have the lash set at .019 per the service manual that is all i need to do and can put the valve cover on correct?
  #4 (permalink)
Old 11-06-2009, 10:26 PM
Yes, as long as you set the lash on each valve when it was fully closed.........you should be good to go. I'd run it for a while, see if any are overly noisy, if so pop the valve cover off and check them again.......t/m
  #5 (permalink)
Old 11-07-2009, 06:56 AM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
Quote:
I would run it up to temp and readjust. Also keep in mind they need to be adjusted every few thousand miles. I do them with my oil change on solid lifter cars..
Tags
262 , adjust , cylinder , cylinder head , doyou , f250 , ford , heads , lash , lifters , push rod , valve , vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
