Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2009, 02:50 AM
03 Power Stroke 03 Power Stroke is offline
03 Power Stroke is starting off with a positive reputation.
2003 6.0 Smokin Like a Chimney
Just performed EGR Delete to eliminate White/Grey Smoke.
Did not work, went for Cheapest fix first,. (96k) Drives fine has plenty of power No noticable water consumtion, No frothy oil. When vehicle warms up starts smokin white/Grey even at idle but worse under load. Only after warm is it real Noticable.
Had Milage Maximezer plug in on truck removed during EGR Delete.
New to Powerstrokes 6 month owner.
Short on cash but will do what it takes to fix it right.
Help, Ideas, Solutions (Explosives do not count)?
Will only buy Ford: Since the Great Depression and this recession Ford is the only Motor Company that has not taken a bail out!!!
  #2 (permalink)
Old 11-06-2009, 08:42 AM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
did you delete the valve too? pull it and take a look.
did you check the outlet on the turbo and see if you have a failed oil seal?
other then the smoke does it run fine?
  #3 (permalink)
Old 11-06-2009, 02:20 PM
Cleaned and reinstalled egr valve. Per instructions. Did not see any more oil than is present on air side. Replaced gasket and lower seal in. Oil line. No visible oil accept on air side. Removed cooler and installed all components per instructions.
Responding from blackberry harder than computor. Puffs when cold smokes when warm
I
  #4 (permalink)
Old 11-06-2009, 02:23 PM
Yes it runs great except for smoke.
Again I am new so be patient.
  #5 (permalink)
Old 11-06-2009, 11:02 PM
hangon2me hangon2me is offline
hangon2me is starting off with a positive reputation.
Sounds like it could be and injector failing and/or injector o-ring issue.
Any codes?
When have you changed the Fuel Filters?
There are so many components that can cause it to smoke.
__________________
2005 F350 4X4 King Ranch long bed
BF Goodrich KM2 Mud-terrain 35/12.50/R18, Bush-wacker's, level kit, ARP Studs, Accufab intake Elbow, SCT X3 with Spartin Tunes,Full EGR Delete, Pyrometer in a single pod,Full 4" Magnaflow turbo back exhaust with 5" tip w/ modified Cat to 4" inlet/outlet, Zoodad, CCV Re-Route
  #6 (permalink)
Old 11-06-2009, 11:09 PM
I replaced fuel filters about 2 months ago when o-ring failed on upper filter.
Stinks bad and I think it's a little bit more thirsty than normal. When I drove it to warm it up and top off coolant went about 15 miles and the fuel gauge moved. Burped it twice and level is right at (min line) where I left it.
No codes showing at parts store, but they can not show anything that doesn't trip check engine light. Have not got gauges or tuner yet. That was in the works before the chimney started. Clues pointed to egr cooler(thats where I began) from every one that I talked to, and read about on the different Ford forums.
**Cheezit I did not notice anything on Outlet side of turbo, Does Not have a butterfly valve under the intake elbow. (Empty delphi box no components, wires plug into empty conecters.)
  #7 (permalink)
Old 11-06-2009, 11:17 PM
does the exhaust smell sweet or like antifreeze? Or like Diesel?
Did you do the full EGR cooler delete? If not you may have a
bad EGR cooler.
I did the full delete, kept the EGR valve in the intake and plugged in.
I had a 2004 with the same symptoms you are having and it was the EGR cooler.
On my 2005 I took no chances, wasted no time and removed everything.
Take a look at my signature.
__________________
  #8 (permalink)
Old 11-06-2009, 11:19 PM
scottman70's Avatar
scottman70 scottman70 is offline
scottman70 is gaining momentum as a positive member of FTE.
Mine started smoking like a freight train and turned out to be a bad injector.....
  #9 (permalink)
Old 11-06-2009, 11:26 PM
Did full GOS Cooler delete, cleaned and left EGR Valve installed and plugged in. Stinks like diesel.
  #10 (permalink)
Old 11-06-2009, 11:28 PM
How do I go about checking injectors? Any links to good reading? Great thing about these sites some one has experienced what ever you can imagine!
  #11 (permalink)
Old 11-06-2009, 11:35 PM
Like scottman70 said you may have an injector gone south.
Please go tomorrow and have it hooked up to a scanner to determine
which injector it is.
Caution: I would not drive it (other than to the dealer or shop), you may
damage your cylinder(s) wall(s) due to washing away the oil, Diesel fuel
is not a very good lubricate.
Keep us posted.....
__________________
  #12 (permalink)
Old 11-06-2009, 11:38 PM
Thanks for the info.
Will try to accomplish in A.M. Truck driver so I'll keep you informed as I can.
  #13 (permalink)
Old 11-07-2009, 12:00 PM
scottman70's Avatar
Keep us posted.....
I 2nd the above quote! Don't drive it with a bad injector too much, could do major damage!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
