Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 10:49 PM
Green_Monster Green_Monster is online now
Green_Monster is starting off with a positive reputation.
Question ZF 4x4 in a 4x2 major hurdles?
I have come across about 12 zf5 4x4 trannys in the past 2 days for under $400 but no 4x2 for under $1000 what would be the major hurdle in this conversion if a 4x4 was used. Drive shaft length? crossmember location? Driveline e-brake?( I like the drive line ebrake by the way? I did a search but missed the specifics I have a guy who will hold the tranny till morning so my research time is short.
If in the end it wil cost me the same please feel free to say so no ttrying to waste any ones time.
thanks
Matt
__________________
1995 F250 4x2 reg Cab Long Bed 351 e4od 4.10ls Farm Truck
2008 Honda Ridgeline RTS Daily Driver for my business
2001 Chevy Silverado 1500 ec/sb 4x4 Z71 - wife's horsey hauler
  #2 (permalink)
Old 11-05-2009, 11:53 PM
RJG1987's Avatar
RJG1987 RJG1987 is offline
RJG1987 is starting off with a positive reputation.
i had a tough time finding a 5 speed, i wanted a zf but there gone where i am. I was lucky to get a trans from a reputable place for $450 that looked like crap when i loaded it on my other truck, but so far its ok, best of luck, pm me if your in a jam and have no luck and i could get the ## of the yard
  #3 (permalink)
Old 11-06-2009, 01:35 AM
SparkyShaft SparkyShaft is offline
SparkyShaft is starting off with a positive reputation.
I dont know what year your truck/tranny? is to say as far as to movin the crossmember but if it does the holes are already in the frame for jus about any tranny swap 4x4 or otherwise, as far as complications, none other than you need a 4x4 transfer case an a 4x4 driveshaft to right length. Also determine about your clutch as far as was your previous tranny internal slave cylinder or external. My truck is like that with a borg warner granny low 4 speed, with borg warner 1356 transfer case, with a 4x4 driveshaft, with no front drive shaft an a 4x2 front axle, waiting for my front axle to go in. Drive it all the time.
  #4 (permalink)
Old 11-06-2009, 02:26 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
So you would be using a 4wd tranny/t-case on a 2wd truck? If you aren't converting it to 4wd and just plan to have a t-case hanging under the truck, I think the driveshaft length would be your only other issue. If this is for the 95 in your sig, then you have no speedo cable to worry about.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #5 (permalink)
Old 11-06-2009, 01:40 PM
Nope not wanting to use t-case just tranny I have 95 f250 4x2 reg cab long bed w/ 5.8 and e4od
__________________
  #6 (permalink)
Old 11-06-2009, 01:43 PM
andym's Avatar
andym andym is offline
1989 Ford F-150
My Garage
andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation.
Send me a couple of those 4x4 ZF trannies for under $400 while you're at it.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #7 (permalink)
Old 11-06-2009, 02:05 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
^^^^^^^exactly what i was thinking.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #8 (permalink)
Old 11-06-2009, 03:22 PM
more than happy to do a little coordinating/shipping if need be...if you are serious
__________________
  #9 (permalink)
Old 11-06-2009, 03:25 PM
quicklook2's Avatar
thanks, but i have more projects then i need already.
besides i like my e4od.
__________________
  #10 (permalink)
Old 11-06-2009, 04:45 PM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
It is my understanding that you cannot use a 4x4 ZF on a 4x2 without the xfer case because the transmission cases are different.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #11 (permalink)
Old 11-06-2009, 06:56 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel is starting off with a positive reputation.
The 4x4 ZF and the 4x2 ZFs are not interchangable without alot of work. To use the 4x4 transmission without a tcase bolted to it, you would need to completely disassemble the transmission to swap in a 4x2 tailshaft and housing. You could run the 4x4 trans w/ a transfer case and no front driveshaft, but then you would need to shorten your rear shaft. Really the cheapest and easiest option would be to hold out for another 4x2 version.
__________________
1989 F250 4x4, 351W, ZF S542, 4:10s, Upgraded to Dana 50 TTB front, 4" suspension lift 33" street, 38" swampers for when things get crazy!
1995 F150 4x4 300 I6, M5OD, 188000mi Daily Driver! SOLD!!!
1995 F150 4x4 302 auto, 6" suspension lift, 33" tires 67k mi NEW Daily Driver
http://www.ford-trucks.com/forums/image.php?type=sigpic&userid=207478&dateline=12337  01805
  #12 (permalink)
Old 11-06-2009, 07:46 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
The 4x2 F-Superdutys of these years used a 4x4 ZF with a parking brake mounted to the tailshaft. This setup may work in your truck too, although you will mostly likely need a new or custom driveshaft.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #13 (permalink)
Old 11-06-2009, 09:11 PM
yeah but that was a bb zf adding a 460 would only piss off the warden I mean wife haha
__________________
  #14 (permalink)
Old 11-07-2009, 02:36 PM
EPNCSU2006's Avatar
The engine is on the other end of the transmission . ZF's website has parts lists, so you could compare and see for sure if the big block 4x4 rear case is the same as the small block 4x4 rear case. If they are the same, I don't see why the parking brake couldn't be bolted on a small block ZF.
__________________
Eric
  #15 (permalink)
Old 11-07-2009, 04:27 PM
i thought he zf ha d an integral bell housing? so bb and sb were not interchangeable?
__________________
Tags
150 , 4x2 , 4x4 , 4x4in , axle , conversion , f350 , ford , frame , front , specs , speedo , swap , trans , transmission , zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
