Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 10:00 PM
DaytonaTunnel's Avatar
DaytonaTunnel DaytonaTunnel is online now
DaytonaTunnel is starting off with a positive reputation.
Intercooler...
Man it's been a LONG time since I've done any work to my PSD. Kinda had the urge to see what's new out there. What is the easiest I/C to add, is it still the '99 unit ? What else is new in the "squeeze more power out" world ? Here's a quick highlight of what I've done to my truck. BTW she just rolled 173K w/a tired stock tranny !!!
Hypermax HOT chip (1500* pre turbo on a full throttle pass)
Beans stage II injectors
removed the EBPV
downpipe w/ 4" straight pipe
H/P oil balancing line
K&N in the stock housing (opened up and smoothed the inlet)
5" lift w 37's
4.10's
I did all these mods early in '99. It saw daily use for 7ish years, now it sits in the shop most of the time. It's been a GREAT truck !!!
__________________
Chris
`67 Fairlane,`79 F-150 4X4 shortbox, '79 F-150 4X4 shortbox (future project), `79 CrewCab 4X4 shortbox (in the works), '79 F-250 4X4 Supercab (parts donator), '93 Accord, '94 Civic, `94 21' Eliminator Daytona (blown BBF), `97 F-350 4X4 CrewCab
  #2 (permalink)
Old 11-06-2009, 12:34 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
well you could start by switching your tuning perhaps.. i have heard that hypermax is fairly mild on their tuning. just for EGT comparison.. my truck is still tuned for stage 1's. i have stage 2 DIY injectors in it w/ an intercooler, 6637 intake, 3" dp, 5" stacks, etc. my truck pulls around 1600* in a 1/4 mile pass. so thats from 0-96 or 97mph.
have you upgraded the HPOP on it?????? that would also be a good upgrade for those stage 2's.
on the ICs. most ppl are still using the SD 7.3L IC, but there are quite a few ppl going to the 6.0L IC now b/c they flow more effiently than the 7.3 IC does. i would also switch that K & N over to the 6637 if it was me, but if you like your K & N cool deal. haha.
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #3 (permalink)
Old 11-07-2009, 11:18 AM
I have not upgraded the HPOP. I've been reading here about some upgrades, but at this time mine still works well so I don't want to pull it out.
Are the 6.0 I/C's harder to install ?
__________________
Chris
  #4 (permalink)
Old 11-07-2009, 11:30 AM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
1996 Ford F-250
cowmilker08 is starting off with a positive reputation.
The stock HPOP cannot truly bring alive stage IIs, especially if they are 180cc. Another easy mod that'll help is the FPR shim. There's the 140 V idm mod. If your looking for a tranny, BTS has a good rep around here. Lots of people switch to electric fuel. There's also a lot of turbocharger options now.
__________________
Phil
1996 F-250HD
"Wake up and smell the scent of a Powerstroke starting on a cold, snowy morning!"
  #5 (permalink)
Old 11-07-2009, 05:22 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
I'm about to find out how hard it is to install a 6.0 cooler and a 4739 tranny cooler in front of my radiator. Got both and all parts just need time. It's gonna be a TIGHT fit for sure.
__________________
Darin I BLEED BLUE
1976 F250 hboy w/71box 390 "Ol'brown"
1997 F250 HD 7.3 10k 3-4" downpipe w/straightpipe 6637 intake ebpv gone
1966 Ford Fairlane drag car 514cu.
  #6 (permalink)
Old 11-07-2009, 06:22 PM
I forgot to list the FP mod, did that a long time as well. What is the 140 V idm mod ? I know I'm leaving a little on the table with myu current HPOP, but back in the day there wasn't any options of modifing them. Is there a detailed link on it ? THANKS !!!
__________________
Chris
  #7 (permalink)
Old 11-09-2009, 03:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP has a good reputation on FTE. RÖENTGEEP has a good reputation on FTE.
Quote:
Read here:
Powerstroke Diesel IDM mod
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 143K.
DIY intake and exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*.
«Primum non nosere»
  #8 (permalink)
Old 11-09-2009, 03:51 PM
THANKS !!!
__________________
Chris
  #9 (permalink)
Old 11-09-2009, 07:34 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Talking
THANKS !!!
No problem, any time, you are welcome.
__________________
«Primum non nosere»
  #10 (permalink)
Old 11-10-2009, 01:44 PM
Andy's250's Avatar
Andy's250 Andy's250 is offline
Andy's250 is starting off with a positive reputation.
you can get a SD hpop for pretty cheap i think, its a 17* instead of 15 and its supposed to help alot with bigger injectors
__________________
"The only reason most American Families do not own an elephant is because they have never been offered one on an installment plan"
'96 f-250 5 speed 3.55's 280k miles, 6637 intake, 120 idm, 3" dp 4" straight pipe, ICP mod, gauges
  #11 (permalink)
Old 11-10-2009, 03:08 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
I just installed a used 17* pump and I'm not pulling codes no matter how hard I push her now. Used to pull codes all the time.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
  #12 (permalink)
Old 11-10-2009, 05:33 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is starting off with a positive reputation.
My dad put a banks IC in his 6.0 SD which means I have a free 6.0 stock IC. I sure would like to put it in front of my truck some day. how big of a job is it? theres already the radiator, condenser, and trans cooler out there. i looked in there and it doesnt look like it'll fit. has any one put the 6.0 cooler in their OBS truck? how tough was it. what kind of performance gains should one expect from doin this? seems like the whole nose would need to come off the truck.
__________________
1997 Ford F-250HD CC SB 4X4 3.55s 7.3 PSD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
