Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 09:52 PM
6litrefan 6litrefan is offline
6litrefan is starting off with a positive reputation.
quick ? on coolant flush procedure in 6.0 bible...:)
Here is the link for one of the coolant flush procedures in the 6.0 bible....my question is on step #5 it says "Drive truck until temp guage goes to normal and thermostat opens."...ok so you of course start procedure with a cold truck i assume...so once you do the first drive after adding distilled water..and you get her up to operating temp and pull it in the drive and drain and refill.....can you immediately do another drive or do I have to let the truck cool back down..."which would take hours...lol"...What i am saying is that once my truck reaches operating temps and i shut it down...it is at or close to temp for a long while after shut down...so pretty much need to know if i can do these drives with distilled water back to back or do i need to wait for cool down in between.....I would think not but thought I would ask to make sure...thanks for any input guys!
Ryan
__________________
2007 F-250 Crew Cab 4x4 6.0L Diesel
CCV MOD
MBRP 4" Turbo-back "no kitty"
more to come!
  #2 (permalink)
Old 11-05-2009, 09:57 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
I did not want to put cold water in a hot engine. I waited.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #3 (permalink)
Old 11-05-2009, 10:05 PM
That is a good point Bismic...yeah i guess that would be a good way to crack a block...how long did you wait in between..i mean is this something that can take days too complete?
__________________
CCV MOD
more to come!
  #4 (permalink)
Old 11-05-2009, 10:22 PM
bismic's Avatar
I just chose to do mine on a day when there was a lot of football on. Just took my time. I guess I waited an hour for it to cool. 69cj just did his and he removed the thermostat. His way is better since he did not have to get the engine hot, but mine worked fine for me. Also, his way is what is described in the Workshop Manual.
__________________
Mark
  #5 (permalink)
Old 11-06-2009, 10:59 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
Pull the t-stat and you can do a flush in 5 min. and the engine never gets hot enough for the next batch of fresh water to hurt it. 5 flushes takes a long time with the t-stat out and a lot longer with it in. For the drain I, 1st open petcock, 2. pull lower hose and 3. pull block plug on drivers side. Reverse procedure for next flush. Do 5 times with distilled water and the last flush will look like you can drink it.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #6 (permalink)
Old 11-06-2009, 12:38 PM
BobbyB BobbyB is offline
BobbyB is starting off with a positive reputation.
Why distilled water?
  #7 (permalink)
Old 11-06-2009, 01:12 PM
Quote:
No minerals or other crap in it to contaminate cooling system. Also a good time to install coolant filter if you don't already have one.
__________________
"71 Triumph Trident
173rd Abn.
  #8 (permalink)
Old 11-06-2009, 02:01 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe is gaining momentum as a positive member of FTE. Powerstroke_wannabe is gaining momentum as a positive member of FTE.
I also waited an hour between drain/fill cycles. Aside from what's already been mentioned, this allowed the fluid to cool so that there was no risk of getting scalded when I drained the fluid.
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Peragon Folding Bed Cover, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals (Kitty ran away), ICON Dual Steering Stabilizer Kit w/Bilstein 5100 Shocks, Nitto Terra Grappler AT 295/70-R18
  #9 (permalink)
Old 11-06-2009, 02:11 PM
Quote:
Pull the t-stat, run for 5 min. and you don't have this problem.
__________________
"71 Triumph Trident
173rd Abn.
  #10 (permalink)
Old 11-07-2009, 12:43 AM
69cj...where is the t-stat and how do you remove it???.......
__________________
CCV MOD
more to come!
  #11 (permalink)
Old 11-07-2009, 10:31 AM
Engine side of upper radiator hose. Four nuts. Remove two nuts then pressure switch bracket. Then two more nuts and the assembly comes off. Depress and rotate t-stat to remove from housing and then reinstall housing with old O ring. When all work is complete reinstall t-stat and housing with a new O ring. 5 bucks at dealer.
__________________
"71 Triumph Trident
173rd Abn.
  #12 (permalink)
Old 11-07-2009, 02:23 PM
03-6L-X 03-6L-X is offline
03-6L-X is starting off with a positive reputation.
I think this was written by Beachbumcook:
Based on what has been stated above you can either leave Tstat in or out.
6.0L Coolant Flush Procedure
Here is what you do.... (I do it every 50,000 miles just because it is fun to do and I am anal about my maintenance).
1) Buy 4 gallons of Ford Premium Gold coolant at dealer
2) Buy 15 gallons of distilled water at local grocery store.
3) Drop lower radiator hose until empty.
4) Reconnect hose and add distilled water to degas bottle until full.
5) Drive truck until temp gauge goes to normal and thermostat opens.
6) Repeat steps #3 through #5 no less than 4 or 5 times (depends on distilled water amount used) - I can't remember?
7) You now have 100% distilled water in your system.
8) Drop lower hose 1 last time, drain and reconnect.
9) Look in manual for your system capacity and for a 50/50% refill of coolant just add the coolant straight into your degas bottle up to the amount that equals a 50/50% concentration.
10) Start motor and add distilled water to bring system level to the MIN mark on degas bottle.
11) Drive truck around to open thermostat and let cool 1 or twice to purge any air. May need to add more distilled water (don't add coolant)... but when done you have flushed your entire system and have a perfect 50/50% concentration of coolant and distilled water!!!!
__________________
03 EB Ex 4X4 6.0L PSD BD 21 May 2003
EGR Valve replaced @ 46,177
Donaldson AF/HFCM Drain Plug
Bilstein Shocks/Firestone Ride-Rite/Rancho Steerling Stabilizer
04 Signal TT Mirrors/Prodigy Brake Controller
  #13 (permalink)
Old 11-07-2009, 03:30 PM
bismic's Avatar
Pulling the T-stat speeds up the process a BUNCH! .... and I would not use the VC-9 without pulling the thermostat.
__________________
Mark
  #14 (permalink)
Old 11-10-2009, 01:38 PM
Hey 69cj....so what you are saying is that with the stat removed, I would not have to actually go out and drive the truck i can just let it idle and circulate in the driveway for 5 minutes???...and then drain and fill again immediately...?
__________________
CCV MOD
more to come!
  #15 (permalink)
Old 11-10-2009, 02:08 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
That's what he said......
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
Tags
2005 , 60 , bible , cleaner , coolant , cooling , diesel , drain , f250 , filter , flush , ford , iron , powerstroke , recommendations
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
