quick ? on coolant flush procedure in 6.0 bible...:)
#46
#47
Your question kind of got lost in the bickering, so I will backtrack and comment. I just changed my coolant at 65k miles. As you can see, it was pretty brown. Truck is running perfect as far as I know. So does that look similar to yours? I don't think it is anything to be worried about, but it is time to change it.
#48
Coolant should be free of all contaminants (old or new). First, did you have a problem that was previously corrected and the radiator fluid not changed, cleaned and flushed... or you have a new problem of oil and blow-by getting into your cooling system (EGR cooler, warped heads... or something serious).
Good luck,
#49
The oil floating on mine was residue in the bucket. It's not much oil at all, and the camera highlighted the difference in color.
I thought mine looked pretty bad. Those of you who have flushed yours, how did your first drain compare to mine?
#50
#52
It doesn't take much brown color looking down in a bucket to make it look dark.
If you flushed 5 times, you still have about 3% of the original coolant mix.
1 = 50%
2 = 25%
3 = 12%
4 = 6%
5 = 3%
And that's best case, assuming you got a good mix after each flush, which is doubtful.
I don't think simple green is going to do anything for the rust. It's a good oil cutter, but the iron cleaner will do a better job of cleaning up the rust. But more clear water flushes will further reduce the % of original rusty water too.
If you fill a clear quart jar with the water you just drained out, I'll bet you will discover it is clearer than you think.
1 = 50%
2 = 25%
3 = 12%
4 = 6%
5 = 3%
#53
on
the brown color is rust. its caused by a PH balance issue. Im not a chemist so I cant really tell you the best cure other then to flush it drive it and flush it drive till its clean then flush it with distilled water and vc9.
have you drained the block on both sides yet? that may help you speed the process.
#55
#56
The flush procedure that I wrote up and has been posted many times does not indicate to take the t-stat out. I personally, do not want to mess with it and I just drive my truck several miles in between each flush (with heater on) and with distilled water and after the 5th time, that is all I have left... 100% distilled water.
Drop it one more time, add 3.5 - 3.7 gallons of coolant (3.7 since I have a coolant filter) and all is well.
Now... if you have a lot of sediment or oily residue, then you need to use Simple Green and the VC-9 cleaners. I would use tap water to flush the heck out of it as it is cheaper than distilled water. Maybe open the pet-**** up and let the hose run into the degas bottle while your truck is running and the heater is on. Eventually, the key is to get all the "gunk" out, Simple Green out and the VC-9 cleaner.
Then... do my flush procedure with the distilled water to get the tap water out... and your hopefully back to a perfect 50/50 mix of distilled water and coolant.
Good luck,
Stewart_H
508
09-15-2023 04:57 PM
