what are you trying to gain? the 5.8 (351w) is a better motor for the bronco then the 5.0. for this to work you would need the entire wiring harness from a vehicle running a 5.0/e4od you will also need the computer from that same vehicle. this will also require a 5.0/e4od flex plate, exhaust Y pipe etc...
so even though it will fit the vehicle you mention as a donor doesnt have everything you need to complete this swap correctly. so explain to us why your wanting to swap motors so we can give you the best option which off hand would be to just find another complete 5.8 and drop it in place of what you currently have.
