Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 08:06 PM
whitesdford's Avatar
whitesdford whitesdford is offline
whitesdford is starting off with a positive reputation.
Transmisson flush after questions
Just flushed the tranny by draining the pan, then taking the cooler line off the rear of tranny, running engine, pumping it all out, and refill.
Now a couple of questions....only took like 9 quarts of oil to refill. Seems like it should be more.
Second question, oil still looks dirty.
Where was the remaining oil when I flushed. I thought that when you pulled the cooler line off the back of the tranny and used the pump it pumped it all out? When I shut the engine off, there wasnt any oil left coming out of the hose from the tranny. The only thing I didnt do, didnt think of it at the time, was shift between gears while draining the oil.
Any ideas?
__________________
2001 CC 4X4 7.3 PSD, Auto, LB Dually
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
  #2 (permalink)
Old 11-05-2009, 08:15 PM
Nick 99's Avatar
Nick 99 Nick 99 is offline
Nick 99 is starting off with a positive reputation.
There is probably a large amount of tranny fluid in the torque converter.
__________________
Sometimes I sits an thinks, an sometimes I jus sits.
  #3 (permalink)
Old 11-05-2009, 08:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
Here's how you do it:
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
If you follow ALL of the steps it will get all the fluid changed. You only did a few of the steps. Now that you have old and new fluid mixed I recommend you buy 20 quarts of MERCON V (the procedure needs updating for that) and start over.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 11-05-2009, 08:38 PM
clintbonnie clintbonnie is offline
clintbonnie is gaining momentum as a positive member of FTE. clintbonnie is gaining momentum as a positive member of FTE.
Interesting... according to the above "how to" it says to remove the line off the back of the trans & run the engine to remove the oil from the TC. maybe you did not run the engine long enough.. Did you run the engine after filling the trans with the 9 quarts?? You must do this inorder to refill the TC.
__________________
Clint... Early 99, F350, 4X4, Auto, DRW, S-Cab, Gauges, Diablosport 60 HP, OilGuard, Tru-Cool, 5% Biodiesel, Shell Synthetic 5w40, Western Diesel TurboRamAir, MagnaFlow Exhaust, SSHPX, CCV Mod, Fuel Line/Tank Mod., Speed Bleeders, Bilstiens....
  #5 (permalink)
Old 11-05-2009, 08:41 PM
I actually pulled the line, ran the engine, then drained the pan, then refilled, wonder if thats why there is still crappy oil in there....
__________________
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
  #6 (permalink)
Old 11-05-2009, 08:43 PM
Thanks Mark for the link. I'll redo the flush tomorrow! I added a tranny filter while I was doing the first flush, better swap that too.
Hopefully the transmission still shifts when all this is over, Ive heard stories that when you flush, sometimes the tranny goes out shortly after....
__________________
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
  #7 (permalink)
Old 11-06-2009, 12:40 PM
Quote:
If you ran the engine long enough the pan should only have a very small amount of fluid in it. And if you only ran it once you didn't even come close to changing all of the fluid.
If the trans dies after a flush either it was severely damaged before the flush, or the flush was done improperly and damaged it. If it's done right a good trans will only be helped, not hurt.
__________________
Mark
  #8 (permalink)
Old 11-06-2009, 12:52 PM
caleb90's Avatar
caleb90 caleb90 is offline
caleb90 is starting off with a positive reputation.
not to hyjack this thread,but ive always heard that you shouldnt flush a tranny over 50,000 miles thats never had it done before.I was told not to do this because atf is a detergent and the new fluid will pick up all the stuff that never made it to the filter and will cause problems and make the tranny slip.im just wondering if this is correct.
__________________
Caleb's
2001 f350 xlt superduty excab short box 4x4 forged rods ,rebuilt ticking time bomb diode tranny 3.73 gears with 100,500miles ccv mod 6637mod foil delete zoodad mod 10k mod and strait pipe. with more mods to come with time.
http://www.guzzle7pt3.com/index.php
  #9 (permalink)
Old 11-06-2009, 03:42 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Caleb,
Read Mark's sig.
I have even used this procedure on my daily driver car with the blessings of Nissandoc.
  #10 (permalink)
Old 11-06-2009, 06:27 PM
caleb90's Avatar
im not saying i dont trust him,i was asking if that was true or not, its just some ive always heard from the old timers.
Quote:
Originally Posted by PaysonPSD View Post
Caleb,
Read Mark's sig.
__________________
Caleb's
  #11 (permalink)
Old 11-07-2009, 04:38 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD is starting off with a positive reputation.
I think any time this debate comes up you always have the same responses. Either you should never touch the transmission, or you should regularly flush and fill. No matter what vehicle you are talking about you will have both responses come up. I am of the belief that it is similar to changing your oil, lets say for instance you bought your truck used, not really knowing the previous maintenance intervals, such is the case with transmission service. Anyway without knowing for sure, would you simple drain about 1/2 the oil, change the filter and top it off, because you wouldn't want to "break loose" any of the sludge the rest of the oil is holding onto? My point maybe the best way for the first time is to drain and remove pan, inspect filter, if no large chunks or severely burned oil are present go ahead and flush it. If chunks or burned fluid are then you're close to a rebuild anyway, so maybe you can gain a little extra time by simply installing new filter and 1/2 the new fluid, skipping the flush and cross your fingers for the best, just my humble opinion.
__________________
Alan
2000 F-350 CC SRW 4WD
AIH delete, 6637 Filter, Wastegate Disable, Foil Delete, 50Cent Mod, Muffler delete 235,00 Miles and counting DP Tuner soon!
  #12 (permalink)
Old 11-07-2009, 07:55 AM
Whitey Ford Whitey Ford is offline
Heavy Duty User
Whitey Ford is gaining momentum as a positive member of FTE.
With all due respect, a transmission that has been stressed by improper maintenance (one that didn't have regular 30k mile ATF changes), would have multiple variables of wear that would be impossible to calculate. Thus, a conclusion to the cause of the failure could not be accurately predicted.
  #13 (permalink)
Old 11-07-2009, 08:02 AM
BigAlsPSD's Avatar
I agree just bringing up the point it is always a HOT topic. And to your point would you flush this inaccurate prediction or leave the trans alone? Like I said if you know the maintenance intervals its an easy call but if unknown I believe you will have people from both camps offer their opinions. Which is more accurate I honestly don't know? Just offering my opinion.
__________________
Alan
  #14 (permalink)
Old 11-07-2009, 08:59 AM
There is some truth, but not much, to the claims that flushing an older trans will kill it. Here's how I think it happens.
Someone ignores their transmission until it has A LOT of miles, and then it starts having problems. The first thing they try is changing the fluid. The problem is that they ignored it until it had major damage. The new fluid couldn't fix the damaged trans, and then it dies. If they hadn't changed the fluid it would also have died, but they don't know it.
New fluid is ALWAYS better. Sometimes it's too late, but the new fluid did NOT cause the failure. Neglect did.
__________________
Mark
  #15 (permalink)
Old 11-07-2009, 05:12 PM
Just flushed the tranny again the right way, wow, there was a lot of bad oil still left in there. Oil on the stick is nice and red again. Thanks all of you who helped me on this, repped as many of you as I could.
__________________
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
