Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 07:34 PM
302lx 302lx is offline
302lx is starting off with a positive reputation.
Replaced the GEM.. need help
Hey all! im looking for a diagram of the fuse block .. to know what fuse controls what? It seems to be going into 4x4 but the light dosent work just low range .. is there a fuse that controls this? Or did I buy a junk GEM? THANKS !!
  #2 (permalink)
Old 11-05-2009, 07:52 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
GEM modules need to be programmed by a dealer for the vehicle in which it is to be installed.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 11-05-2009, 09:07 PM
same module out of same kind of truck ??should be same?? If not then everyone of them is different? everything else works
  #4 (permalink)
Old 11-06-2009, 02:31 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 is starting off with a positive reputation.
Without knowing how the function works in total for 4X4 HI and 4X4 LOW, how do you know it's the GEM?
There is a switch, a motor on the transmission, relays on the firewall, a vacuum actuator on the front axle assembly and vacuum hoses involved.
The GEM also controls other functions besides 4wd.
To explain it all here is a lot of text to type.
Good luck.
  #5 (permalink)
Old 11-06-2009, 04:11 PM
it worked fine until I changed GEM ! now it just doesnt come on .. Im hoping it is going in 4x4 i could live without the light
  #6 (permalink)
Old 11-07-2009, 01:21 AM
SMok SMok is offline
SMok is starting off with a positive reputation.
the truck you took it out of was probably a 2 wheel drive.
  #7 (permalink)
Old 11-07-2009, 06:41 AM
no! 4x4 low range works explain that and it said 4x4 on gem
does it matter oin the transmission manual or automatic
  #8 (permalink)
Old 11-07-2009, 10:46 AM
yes it does
Tags
97 , f150 , ford , gem , motors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
