The info in your cam description gives a torque mid-range of 3000 to 4000 rpm. I'd start with those parameters for a converter stall #. Much less than 2800 & the combo will probably be a real dog until it reaches 3000+....
If you change the gears to 4.11 or better, you might get away with a larger converter [~2500 stall] which will run cooler on the street.....
