with the truck off put your switch on the front tank, have some one put the key in the on position while you listen by the tank. you can hear the pump turn on. if it is not turning on it could be the pump. if it does turn on and it is just not changing to the front tank then i can be your selector valve. also check and make sure you are getting power to the front pump. hope his helps
