Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 06:35 PM
rollinginmudgirl rollinginmudgirl is offline
rollinginmudgirl is starting off with a positive reputation.
flashing overdrive light???
I have a 1995 F250. A couple months after I bought the truck it started to blow fuses. When it would blow fuses however, the blown fuses would not coincide with the things that were wrong with it. Then alltogether one day it stopped blowing them. Now the overdrive light flashes at random times while I drive and it refuses to shift. Got any ideas??? Shift cellenoid??
  #2 (permalink)
Old 11-05-2009, 06:42 PM
Action4478's Avatar
Action4478 Action4478 is offline
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
Quote:
Welcome to FTE ..
When I had the flashing OD light , it was the wiring to the VSS on top of the rear axle . If the light flashed , there will be a code stored in the PCM . May have to go to ford to get the codes read ...
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #3 (permalink)
Old 11-05-2009, 06:57 PM
helifixer's Avatar
helifixer helifixer is offline
Rest in Peace Jake
helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold
I see a lot of this from the wiring in the shift lever, it is a solid wire with a thin insulation and the wire either brakes or the insulation chaffs through and shorts out. the only fix that is worth the time is a new shift lever from ford if this is the problem.
__________________
They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO
Diamond K your complete automotive and truck repair center
  #4 (permalink)
Old 11-05-2009, 06:58 PM
helifixer's Avatar
Rest in Peace Jake
I do see a lot of the VSS / RABS sensors fail and / or go intermittent, but normally that will put the trans in limp mode or shift neck jerking hard.
__________________
Tags
1995 , 73l , 99 , blinking , blinks , f150 , f250 , f350 , flashes , flashing , ford , lever , light , overdrive , powerstroke , shift , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
